November 23, 2024, 02:26:39 am *
Pages: 1 [2] 3  All
Author Topic: A Visit to Nicks and a Surprise Finding  (Read 43620 times)
« Reply #15 on: July 25, 2013, 03:14:00 pm »
Brian hi,
Your description of sound with and woithout the PCIe X-Sound card is very similar to what I was finding, the ATx replacement coule be a good direction to try. I hope the Seasonic works for you as well.
Best Nick.
Ps I keeping meaning to post the location of SpeedStep and C1E settings in our BIOS for you after you question in the C1E thread. Do you still need to know where they are ?
« Reply #16 on: July 25, 2013, 11:25:08 pm »
Thanks Nick, yeah, figured it out. Will see how the Seasonic sounds.
« Reply #17 on: July 27, 2013, 12:28:13 pm »
So bought and fitted a new ATx power supply that is the same as Pauls. To say there is a transformation in SQ is an understatment. I will post more later when I have time on what has happened and the general effects on SQ and my noise problems.
For now the NEW ATx supply is a Seasonic SS-400FL2. I read a load of ATx reviews on line as research and indead the Seasonic SS-400FL2 does have very good specs on paper (no tests give traces of wideband noise but ill take a look with my scope).
Hi Nick,
I wonder why you have chosen the SS-400FL2 in front of other models like the 460 or 520. Is it because of the better measurements of the 400 model or just because 400w is enough?
« Reply #18 on: July 27, 2013, 12:51:47 pm »
Juan hi,
The main reason was that it was way was in Paul's PC and I was keen to use exactly the same. I put a mains power tester on the PC (3037 CPU) and found that it only uses about 120 watts whilst playing music at normal CPU clock speed so that checked out ok.
The reviews on line of the 400 460 and 520 versions show the larger versions making just a small amount more ripple noise but not sure that this was a problem so I went for the 400w version in the end.
Brian is switching out a corsair ax750 for a seasonic I think so his experience may help understand if my corsair was just a poor unit or if the seasonic is generally a good upgrade.
tillen
« Reply #19 on: July 27, 2013, 05:36:00 pm »
Hello!
I changed a Corsair With a seasonic 520 FL, and there was big differnce in sound quality. Much less noise, and all over better sound.
Arnt
PC- Asrock X79 Extreme 4-M -
« Reply #20 on: July 27, 2013, 05:44:22 pm »
Hello!
Arnt
Arnt,
Very pleased to here that it has worked well. I was a bit concerned that people would give the change a try only to find it was my particular ax750 which was not working. Evidence could be mounting that  as the seasonic may just be better for music.
Regards
« Reply #21 on: July 27, 2013, 06:42:03 pm »
The Seasonic has to be better because the BeQuiet is in the "XXHighEnd PC" !
(both are the same, though not all parts seem to be)
Happy Happy
« Reply #22 on: July 28, 2013, 11:37:10 pm »
Juan hi,
Thanks Nick. So far my Corsair AX 750 is working fine, I do not hear any strange noise nor have I ever been able to hear if the fan is operating or not. The sound is fantastic but who knows...I haven´t tested other ps. I have a bequiet! in my work pc and maybe I´ll give it a try to see if Peter is right  Wink.
I would like to hear from Brian when testing the Seasonic, for now let him enjoy his vacation.
« Reply #23 on: July 29, 2013, 03:38:36 am »
Thanks Juan. Got home this evening. Am expecting the Seasonic by Wednesday. Will hopefully post impressions  soon thereafter, but it could take a bit of listening.  Happy
Spent a couple of hours listening tonight and I just don't see how it can get much better.........
Mamba315
Ferrari NOS1a
« Reply #24 on: July 29, 2013, 05:56:36 pm »
I had read some of this power supply talk yesterday, then this morning I ran across this 'audiophile' computer power supply and thought someone on here maybe crazy enough to try it.  A little expensive since its audiophile... 750-770 USD
http://www.audiocircle.com/index.php?topic=118599.msg1246358;topicseen#new
Matt
« Reply #25 on: July 29, 2013, 10:52:52 pm »
Matt, that one is an external power supply (which is not bad) but you would also need to buy a picoPSU to fit onto the mobo in your music server and break up the 12v into its individual rails.  There are better options than the picoPSU apparently BUT this power supply is only 150w which I doubt would boot a high powered computer such as those recommended for XX and the NOS1.
However, if you had a pc like any of the CAPS machines (including the Zuma) then this power supply would be enough to start them up.
« Reply #26 on: July 30, 2013, 09:17:54 am »
What I got from it is that this only feeds the MoBo (for its explicit purpose).
« Reply #27 on: July 31, 2013, 01:40:33 pm »
So, I received the Seasonic yesterday, installed it last night and had a good two hour session. As Nick found, from the first note I experienced a transformation of my system. A significant layer of glare, which I previously only heard as HF distortion when, say, a vocalist goes from 0 to 60 mph in an instant, was removed. Suddenly  quiet pieces or parts of tracks,where I thought there was no glare,  sounded completely different: more detail, air, and presence. Overall everything sounds way, way less aggressive (Thanks for the glossary!).....and, before yesterday, I never would have described my sound as aggressive.
So Nick, thank you so much for being so conscious of and determined to figure out your noise problem. Thanks, really, for those trips in your car noise hunting. Can you now say that you found the source of the problem? Also, thank you Paul for lugging your gear to Nick's to help trouble shoot the problem. Not an easy task with those Reserator umbilicals hanging off the cpu.
I know its been said a bunch of times before, but I want to acknowledge again what a great community this is. Though we each sit "alone" in our rooms, that we manage to maintain a mutuality  that benefits Peter's project overall and each of us individually, without great sniping or ego upset, is remarkable. It's just so important that folks be willing to share their respective experiences regardless of how experienced or knowledgeable one may be. Given my lack of knowledge and experience in the audio world, it just makes me laugh that I am a participant in this "discussion."
One last thing, several years ago, sitting on my couch, the wisest audio guy I know told me that in audio everything is relative to each person's system, or, as Paul Simon sang, one man's roof is another man's floor. That for the last fifteen months I've been mostly blown away with the sound of my system is what it is. The Seasonic revealed that that sound, in part, was cr*p! Another good laugh!
Hey Juan, how fast can you get to the store.  Happy
« Reply #28 on: July 31, 2013, 02:18:30 pm »
One other thing. The Seasonic vents from the top so if your case requires a top mount PS, like mine, you will likely need a new case. My Seasonic is currently sitting on top of the PC, on a mouse pad should case vibrations cause it to want to slide around. Need to start looking for a new case.
« Reply #29 on: July 31, 2013, 03:43:44 pm »
So, I received the Seasonic yesterday,...
Hi Brian, I get going. You have also purchased the SS-400FL2?.
Pages: 1 [2] 3  All
