November 26, 2024, 02:49:20 am *
Pages: [1] 2 3 4  All
Author Topic: C1E and E1ST speedstep BIOS  (Read 53586 times)
0 Members and 14 Guests are viewing this topic.
« on: July 17, 2013, 10:23:16 pm »
I have been trying to reduce the noise floor of my PC and DAC, and came across a couple of BIOS settings that have significntly changed my sound quality.
Turn off C1E and E1ST speedstep in BIOS settings. They are both involved with slowing the cpu when there is not much load to save power. Its made a large positive  impact on  SQ.
It may be worth trying. Post back any thoughts.
Ps Mani and Brian I think this could be one for you guys if you don't already use the settings.
EDIT just searched the forum and it looks like these settings have been posted on before (I missed it first time around  unhappy ). Anyway this might be a reminder to give the settings a go.
« Reply #1 on: July 18, 2013, 10:59:13 am »
I can´t find E1ST in my Sabertooth Bios, could be instead Intel (R) SpeedStep (TM) Tech?
« Reply #2 on: July 18, 2013, 11:12:48 am »
Ok I get it. It is under Intel PPM Configuration in the Advanced tab. And yes it is Intel (R) SpeedStep (TM) Tech and Intel (R) C-State Tech. I´ll report about SQ changes. Thanks Nick.
« Reply #3 on: July 18, 2013, 11:26:04 am »
Hi Juan,
I had to check for this myself and yes it is about the "Intel Speed Step" (EIST).
« Reply #4 on: July 18, 2013, 12:30:04 pm »
Thanks Nick. Will post when I get a chance to give it a try.
« Reply #5 on: July 18, 2013, 02:02:16 pm »
Juan hi,
Yes E1ST is the SpeedStep setting.
« Reply #6 on: July 18, 2013, 02:18:35 pm »
Hi Nick, I'm currently working out of the country but will give it a go when I get back this weekend.
Cheers, Mani.
« Reply #7 on: July 18, 2013, 02:32:39 pm »
Mani,
You are never at home man. Think about a discman or something.
If they still exist.
NOS1Man, also nice.
Happy travelling (btw, how can you while the weather finally went in the good direction over here).
« Reply #8 on: July 18, 2013, 02:45:09 pm »
A quick test tells me that the sound seems a bit clearer with C1E and E1ST disabled but it it hard to tell the differences having to reboot and enter in the Bios to make the changes, it takes time enough to make difficult to retain in the memory the differences. In any case they are subtle differences but this is what this business is about...
« Reply #9 on: July 18, 2013, 03:46:43 pm »
As I get more time listening it seems more evident that the sound is clearer and the details can be better perceived with C1E and E1ST disabled. I think it's a step forward but I´m not sure if at the long run this sound so clean can tire the ear.
« Reply #10 on: July 18, 2013, 04:26:35 pm »
You are never at home man. Think about a discman or something...
Yep, greetings from Houston! Unfortunately I have to go where my clients ask me to go. You know, having a zillion air miles and a Gold card nowhere near makes up for the time lost at home with my family... and of course listening to great music in the evening.
Knowing that I 'need' my music, last Christmas my wife bought me a Dragonfly DAC for my travels. I loaded XX onto my laptop and was getting a really nice sound coming out of my headphones. I mean really nice. But I have Windows Update set to auto on my work laptop and after one of the updates in Feb/Mar, XX stopped working with the Dragonfly. I just haven't had a chance to look into things again since then.
OT:
I'm not sure why but I tend to think a lot about my music system and what I want to do with it when I'm sitting waiting in an airport lounge. My latest thinking tends towards getting rid of the last SMPS in the system - the PC supply. It's already fed from its own dedicated 5KVA balanced transformer, but I'm aware that it must still be injecting a load of cr*p into the PE, some of which I'm sure finds it's way into the electronics. For now, the only solution seems to be a low-powered PC running off a linear supply. But this is simply a no-no with XX. Oh well, I suppose I should stop thinking and just wait for Peter to come up with a solution in time. Somehow I think he will...
Cheers, Mani.
« Reply #11 on: July 18, 2013, 05:06:17 pm »
Mani, I wouldn't be too sure about that. I mean, since I run my PC at 460MHz without issues ...
(still not comparable with a low powered cpu, but still ...)
« Reply #12 on: July 18, 2013, 05:07:12 pm »
I don't think I ever mentioned it, but I always have had this off (for years I mean).
« Reply #13 on: July 18, 2013, 05:46:10 pm »
Even before it appeared in Bios Wink
« Reply #14 on: July 18, 2013, 05:59:42 pm »
P7P55D-E EVO.
But maybe I dreamt it. Also about a 3rd one in this same row of thingies.
Page created in 0.128 seconds with 19 queries.
