November 24, 2024, 05:42:19 am *
Author Topic: Buzzing Noise at playback  (Read 6458 times)
minzyman
« on: July 13, 2013, 11:32:23 pm »
Has anyone experienced this? I have a bothersome buzzing noise that starts just before playback, is not nearly as loud as the music being played, but is nevertheless annoying.
The only thing that affects the noise is entering the NOS1 driver console and changing usb buffer size. At 16ms, the sound is the lowest in frequency (and thus not as annoying). If you change to 12ms, the buzz becomes higher pitched. Change to 8, becomes higher still, etc.
I have a Startech usb3 card installed with Renasys drivers, but switching the usb cable to other usb ports does nothing to eliminate the buzzing.
Any ideas anyone?
/LM
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
« Reply #1 on: July 14, 2013, 05:34:33 pm »
I believe I've heard this a few times. It was always very soft and seems to disappear when music plays. I've never heard it during very soft classical passages, so it's never really bothered me.
« Reply #2 on: July 14, 2013, 07:11:46 pm »
This also happened to me at some point and if I recall correctly, I played with the Q1 parameter to correct this... After I reduced the Q1Factor and Q1 value, it was gone. Maybe you could play with these two just to verify ?
