November 24, 2024, 02:59:36 pm *
Author Topic: XTweaks: Cool When Idle tweak putting all cores at 100% ?  (Read 6654 times)
« on: July 07, 2013, 03:28:57 pm »
Yesterday I just discovered that all the cores were at 100% all the time, though the frequency is limited at 1.2MHZ (from BIOS, from me)...
When I set the "Cool When Idle" tweak at 1 (Cool, not better), the cores goes back to normal.
As for the rest:
Balanced Load: 45
Nervous Rate: 50
Provide Stable Power: 1
Utilize Cores Always: 1
Time Stability (W8): Stable
Time Performance Index: Optimal
« Reply #1 on: July 07, 2013, 03:58:00 pm »
Hi Alain,
I have said this several times, also in Release Notes. This is a Windows 8 bug and either it is reality (which is what I believe) or it is not shown properly.
In either case it is my advice to activate Cool when Idle for Windows 8.
I never tried whether is sounds worse with that 100% behavior. I just never allow(ed) it to happen.
« Reply #2 on: July 07, 2013, 04:46:37 pm »
Hi Alain,
You have not told me to read from version to version often enough Wink
What drove me back to check the cores performance was a "lag" that was happening for some time. But as I mention, the CPU is limited to 1.2GHZ while it is capable of much more - so no worry at this time.
But thanks of course Happy
