November 25, 2024, 04:24:03 am *
Author Topic: Setting UpXX on RAMDisc/IMDisc - License question  (Read 5748 times)
« on: June 30, 2013, 06:26:09 pm »
Can I  just copy/past my existing 9Z-9 XX folder, which is on my C drive, onto my RAMdrive or do I need to get a new activation key?
« Last Edit: June 30, 2013, 06:33:19 pm by PeterSt » Logged
« Reply #1 on: June 30, 2013, 06:33:32 pm »
No new Activation Code needed Brian.
PS: Notice that you also need the XXData folder in there and that the settings in XXHighEnd must be able to find it (see field for it). So, default in there is \XXData which means that if you have that plus copy XXData to rhe root of the RAMDisk, all will work without changing settings.
« Reply #2 on: June 30, 2013, 06:44:11 pm »
Thanks for the quick reply!
Page created in 0.108 seconds with 19 queries.
