November 23, 2024, 03:14:23 am *
Pages: 1 [2] 3 4  All
Author Topic: Windows 8 disappointment.  (Read 69335 times)
« Reply #15 on: July 02, 2013, 11:43:16 am »
Please notice :
Although I use the RAMDisk for Playback Drive myself (which is for technical reasons in my case) I never said that this would improve sound. Or deteriorate it. I just don't know.
FYI
Neither did I. I just like the sound with the Playbackdrive (accidentally on the IMdisk) better than no Playbackdrive!
Not shure yet if I subjectively agree with the second statement on SQ. Maybe this is just a matter of settings.
regards, Coen
« Reply #16 on: July 02, 2013, 12:44:46 pm »
I found that this quality is served by NOT having XXHE on a Ramdisk (or IMdisk)
Totally agree in my system too, Coen. I 've been trying the IMdisk with XXHE and as playback drive and, despite some other problems ( header data not found, sound interruptions and more ) I've found the sound is worse with XXHE in IMDisk and the "magic" is lost.
Coen,
I just was not sure to what degree at least Maxi thinks that XXHighEnd on the RAMDisk and use the RAMDisk as Playback Drive is the same thing, while everybody would find it logical that it is about the Playback Drive.
So, both (either) carry different SQ implications.
And to summarize possible confusion :
If I read all literally and nobody (you, Maxi) is confused in the first place, you both say that the Playback Drive from RAMDisk is for the better, while using XXHighEnd from the RAMDisk sounds worse.
The latter would be against my theories, but this is OK of course. Notice I can not check this because of the technical reasons which just need both to operate from RAMDisk.
I hope this clears up things somewhat.
listening
« Reply #17 on: August 10, 2013, 07:48:42 am »
As posted before there have been some glitches with shutdown and booting Windows 8 again. Sometimes the ramdisk appears, the SQ was terrible or the Metro appeared unexpectedly. Even shutting down via command line did not work. I have identified the hibernate mode as the cause. Sometimes it was functional for no reason. So I disabled the hibernate mode completely using Windows commands: powercfg /H off. This deletes the file hybernate.sys completely too. From now on everthing worked flawless. Happy
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #18 on: August 10, 2013, 04:31:07 pm »
A strange start up issue I've had for months now has been the sudden ability to turn the PC on by hitting and combination of two keyboard keys. In my BIOS there is an option for using the keyboard to turn the PC on after a power failure; however, this has always been disabled. (A while back I enabled/disabled this to see if it helped but it didn't.) Yesterday, for the first time in 3 or 4 months I went into full OS mode from minimized to do basic maintenance--defrag, etc. After going back into minimize I am now not able to start the PC with the keyboard. Just an FYI.
listening
« Reply #19 on: August 20, 2013, 09:28:52 am »
I find another Windows SQ setting which seems to be worth to try out: Setting the process priority from foreground to background. Gives better separation of instruments in my system.
Georg
-> SMSL SU-8 ES9038
« Reply #20 on: August 20, 2013, 06:35:17 pm »
Georg, all,
This is a setting which typically CAN NOT BE REVERSED.
You will think it can (just set it back) but the internal schematic will be all different.
This must be an XXHE setting which btw I recall is already active (somehow, I forgot and can't look in the code at this moment).
listening
« Reply #21 on: August 20, 2013, 06:48:43 pm »
OK, I send it to department placebo  innocent
Georg
-> SMSL SU-8 ES9038
« Reply #22 on: August 21, 2013, 06:07:50 am »
Hi Georg,
Nah, that is not what I implied. Your changed settings for sure will do something. But changing back is not possible. So real comparison is not possible either.
« Reply #23 on: August 26, 2013, 09:50:10 am »
It is time to admit it (again): I cannot reconcile with XX and windows 8at this stage. It is not as bad as the title of this thread suggests, but dispite the many improvements in sound  made by tweaking, I still prefer the trade-offs that XX and windows 7 have.
Do not mistake me for stating that windows 8 does not have excellent sound qualities, it does, sometimes. Yet everytime I (un)voluntary boot into win7 and play some tunes I realise I still much prefer the gentile, spacious and easy presentation .
Next to that every time I boot or shut off win 8, anything can happen. I've had many stalls of the process, sudden hybernates, changed BIOS settings, disappearing and reappearing icons, clicks and interruptions in the sound, etc,etc. and the latest is the systemclock running at half speed.
Win8 seems to work for the forum members with Extreme series CPUs and premium mobos, like the XXHE pc. They are also experiencing some strange stuff though.  Maybe my system is not fit for WIN8 yet I cannot compare.
Regards, Coen
« Reply #24 on: August 26, 2013, 04:54:26 pm »
Coen,
Why are you not using 0.9z-9b ?
The Q5 parameter really matters you know ...
« Reply #25 on: August 26, 2013, 05:48:45 pm »
Never upgraded in win7, dunno why....
Win8 is like in my sig 09z-9b.
I've done a lot of q5 experimenting in win8, it does make for significant diffences but so do other settings. It also about the annoances with the OS though.
Regards, Coen
« Reply #26 on: August 26, 2013, 06:25:34 pm »
Ah, ok Coen. I was talking about W8 only. No need to change anything fo W7.
But maybe something is wrong with your OS install ?
(notice that this may well be the first time that *I* suggest something like that ...)
« Reply #27 on: August 26, 2013, 06:39:48 pm »
I purchased a win8 upgrade disk and I use a dual boot configuration with all practical programs on win7 and win8 as audio only. I suppose this does not work well. Maybe some of the stuff is used between OSses.
Well I thought these are the usual bugs with new software. Could be also be about the RAMdisks, but I prefer the sound with them.
Regards, Coen
« Reply #28 on: August 26, 2013, 06:44:19 pm »
FWIW Coen :
My "final" setup I am using for the best SQ these days is also a dual boot with W7.
« Reply #29 on: August 26, 2013, 08:29:17 pm »
I suspect the sq part is due to my pc setup, apparently better suited to win7.
Others experience(d) also problems like cracks and stops with win8. I think all the booting and shutting off issues are due to "infant diseases" (a nice Dutchism eh!) of the OS. I am not applying any updates since they are shut off and have no permanent internet connection.
Regards, Coen
