Robert
« Reply #15 on: June 28, 2013, 12:24:17 am » |
Cold lowers resistance enabling better sound. Super conductors run at very low temps. Found this bit of trivia and what do you know the Dutch discovered this: Enter superconductors. Soon after its discovery in 1911 by Dutch physicist Heike Kamerlingh Onnes and his collaborators, Cornelis Dorsman, Gerrit Jan Flim and Gilles Holst, superconductivity inspired dreams of no-loss electrical transmission. Unfortunately, there was a catch. Superconductors require very cold temperatures, on the order of 39 kelvins (minus 234 C, minus 389 F) for conventional superconductors. The solid mercury wire that Kamerlingh Onnes used required temperatures below 4.2 K (minus 269.0 C, minus 452.1 F). Even so-called high-temperature superconductors only work their magic below 130 K (minus 143 C, minus 225.7 F).
« Reply #16 on: June 28, 2013, 06:59:27 pm » |
I just had another letter to say that the power company may feel that the first upgrade was not enough. They plan to have the power off for another day soon. I'm hoping that upgrade 2 may be coming
« Reply #17 on: June 28, 2013, 07:51:14 pm » |
And Power On.
« Reply #18 on: August 23, 2014, 12:31:35 pm » |
Hi an update on mains company music system upgrades... The electic company sent another notice asking to do some work on the house meter. Well actually, as seems to be the custom in the UK these days, they threatened to obtain a court order to enter my house to do work on the mains of I did not call them to make an appointment for them to attend..... nice customer service approach !! This time it was "just" the house electric meter that needed swopping out after 25 years. So Wednesday they turn up and do the work, and I don't even think about possible impact on music until Friday when I put some music on at the end of the week. OMG ! I think they installed a Boogytron 2000 or something , sound is absolutely great ! what an upgrade. Looked at another way it's disturbing that the old meter was so s**t for sound quality. Glad to see the back of the old meter that's for sure. Nick.
« Reply #19 on: August 23, 2014, 01:49:00 pm » |
So now that eh ?
The other day our water meter was exchanged. Didn't notice any difference.
Great stuff Nick. Not sure though whether that all should make us happy. To me it seems we can only be lucky when having it right. On to our own generators !
Regards, Peter
« Reply #20 on: August 23, 2014, 02:28:31 pm » |
But I thought you had windmills in Netherlands ? Alain
« Reply #21 on: August 23, 2014, 03:06:19 pm » |
Hahaha. It might surprise you, but with this type of windmills (generating electricity) The Netherlands is most probably the most behind of all in Europe. "We" are always complaining that they destroy the sight. Of course for Holland this is quite easy with all being flat (no hills).
I could easily put one up in my "garden" of any size. I am also so that I would do it no matter the investment (will earn it back later). But a. I wouldn't like such a thing myself (and they are also noisy) but b. I would receive 1500 complaints of the people from the village (where 1500 people live) and never get a license for it.
Solar is the idea really, but then really not because you can NOT earn that back. Not here. So think : 40 years or so if you take all into account (and most people forget half of it). Perpetuum Mobile. That's the sh*t.
« Reply #22 on: August 23, 2014, 03:24:09 pm » |
I am sure you would design blades that do not make noise And the extra is that you will make your own flour I imagine receiving my NOS1 converted to a NOS1a and smelling a nice muffin odor from the box Alain
« Reply #23 on: August 23, 2014, 03:36:45 pm » |
Good idea Alain, but not the very best. https://www.flickr.com/photos/64842591@N06/8615889905This one is 700 meters from here and that is where we get the flour from to bake our own bread (never seen a bakery in years). 700 meters ? hmm ... seems doable for a cable. PS: Funny; I just walked away before pressing Post because the alarm bell went off to take such bread out of the oven ... And I didn't even realize the same subject (OK, now I did).
« Reply #24 on: August 23, 2014, 03:50:05 pm » |
Ah, I see that you don't believe me.
« Reply #25 on: August 23, 2014, 04:00:50 pm » |
But seriously, if someone is able to see an improvement for me ...
haha
« Reply #26 on: August 23, 2014, 04:06:35 pm » |
Here maybe ?
« Reply #27 on: August 23, 2014, 05:12:09 pm » |
Wow, I envy where you are and your ability to prepare all your food, even making your own bread ! And the bread picture... Mmmmm ! I can almost smell it from here ! Wonderful Alain PS: Not that I did not believe you, but I quit a few minutes later to do some shopping - like buying bread haha
« Reply #28 on: August 23, 2014, 05:15:44 pm » |
LOL
« Reply #29 on: August 23, 2014, 05:17:58 pm » |
haha
Your electricity room ??? I know you are joking It looks like a nuclear power plant As for the PCs et al... If I send a few pictures of my house inside, I am sure you will find your management very reassuring Alain
