« on: June 26, 2013, 12:27:59 pm » |
I had to smile yesterday evening. The power distribution company has been doing upgrades to the mains system in my village. Yesterday our house had power cut all day so that the power company could replace the above ground mains distribution wiring to the house across our paddock and up to the house. I think the new wiring has gone back from the house as far as a pole mounted transformer further into the village. I thought it would be fun to try my system and take a listen, had the power company met its most important objective of upgrading my system ? . Well it’s made a real difference to the sound: bass it tightened up and more tuneful, the background is blacker, highs are sweeter and the tone of voices and instruments is much improved. Prior to the EDF (the power company) upgrade I was using W8 and 09-z9 but I was not completely happy with the bass which took a step backwards compared to W7. With the free “mains upgrade” W8 is just where I want it now. Everythnig matters, but it’s especially nice when some things get sorted for free Nick.
« Reply #1 on: June 26, 2013, 01:29:46 pm » |
Hi Nick, You put a smile on my face I imagine my power company asking me if I am interested in an audiophile power grid, with a few dollars more per month I would surely answer "yes" Regards, Alain
« Reply #2 on: June 26, 2013, 01:58:01 pm » |
Is it really a coincidence, but while I'm away from home for a few days, the power company has changed cables throughout the building where I live to follow the rules of the European Community that requires a change every 10 years. Changed cables are the common ones to the entire apartment building, from the taking of the street to the entrance to each home, including grounding. Changed cables are thicker and have a better insulation than the previous ones. So I'm looking forward to coming home to see if I have as much luck as Nick.
« Reply #3 on: June 26, 2013, 02:15:35 pm » |
IOW Juan, Nick scared the hell out of you.
haha
« Reply #4 on: June 26, 2013, 03:27:20 pm » |
haha
Ther's just a soupcon too much altissimo coming through in allegrissimo passages, I think I'll have to demand that EDF they put the old cables back up, this just won't do !.... haha Hope it goes well for you also Juan. Nick.
« Reply #5 on: June 26, 2013, 03:53:48 pm » |
IOW Juan, Nick scared the hell out of you. haha
This upgrade has killed the itch momentarily while I wait my turn to update the NOS1 Thanks Nick. Juan
Robert
« Reply #6 on: June 27, 2013, 01:54:34 am » |
Yes I've had the same experience when power company replaced power cables in the street that dated from 1940's.
Not only did my shaver run faster and the lights brighter, the HiFi sound was much improved.
« Reply #7 on: June 27, 2013, 10:10:31 am » |
I use an analog shaver. Low jitter.
« Reply #8 on: June 27, 2013, 11:07:20 am » |
Me too, triple blade, and SQ (Shaving Quality) is sharp and smooth Juan
« Reply #9 on: June 27, 2013, 11:31:08 am » |
I had to smile yesterday evening. Nice story Nick. The cheapest upgrade for me arrives most winters. The SQ seems to go up whenever there is a thick layer of snow on the ground. I'm not sure exactly why this would be. It could simply be the deadening affect the snow has on background noise or maybe even some sort of damping affect it has on the HV electrical cables outside. Who knows... It's a shame though isn't it that there are so many factors that are simply out of our control. I strongly suspect mobile phone signals, wifi routers and even DECT phones all affect SQ negatively. Mani.
« Reply #10 on: June 27, 2013, 12:04:04 pm » |
I hope your shaver is bit perfect, otherwise you could have some cuts Alain
« Reply #11 on: June 27, 2013, 12:42:08 pm » |
It *is* bit perfect, but the other day my son started using it for the first time, and ... cuts. I'm sure there must be a bug somewhere, but till now I cannot find it. It's a two-blade though. Just saying. Can't do more than 96000 per cm. Shaving Depth is OK (24).
« Reply #12 on: June 27, 2013, 12:48:56 pm » |
The cheapest upgrade for me arrives most winters. The SQ seems to go up whenever there is a thick layer of snow on the ground. I'm not sure exactly why this would be. Can be because in winters here, humidity is relatively very low. At least when it is nicely freezing in a clear sky it will. Normal here is between 55-60% but in winter it can be under 30% easily. Humidity matters the whole world for sound wave propagation. This is not as easy as thinking that water drops prevent waves to travel and is so complicated that I gave up understanding. It is in a similar realm as how the "Sugar Cubes" work. So who understands that. Now you know. Peter
« Reply #13 on: June 27, 2013, 01:50:38 pm » |
I use an analog shaver. Low jitter. I always get jitter first thing in the morning with electric or wet shavers - things improve after the first coffee though Paul
« Reply #14 on: June 27, 2013, 01:53:06 pm » |
No no no ! From coffee one starts shaking. Implies deep cuts ! This is serious; try photography.
