November 25, 2024, 07:55:31 am *
Author Topic: "Win32NT" displayed on Win 7 64 system  (Read 8232 times)
charliemb
« on: June 21, 2013, 11:36:05 pm »
Not a bug, but might be?
On my Windows 7 Ultimate SP1 PC, clearing the playlist erroneously displays "Win32NT" on a 64 bit Win7.  Here's what's actually displayed:
"XXHighEnd Win32NT
Model 0.9-9b"
I'm sure that .9-8-3b displayed ~"XXHighend Win 7"
Settings in my sig are updated
July 2019:
« Reply #1 on: June 22, 2013, 06:26:59 am »
Hi Charlie,
Can you switch on logging, quit XXHighEnd, restart it and then grab the newest XX log file for me ?
PS: Sent you an email as well. Log file an be send via email if you like.
charliemb
« Reply #2 on: June 24, 2013, 06:48:39 pm »
Problem fixed for at least now.
All I did was
    Exit minimized mode(reboot) and enter Normal mode,
    verify W7 in XX,
    verify Winmgmt in task manager,
    Play part of one track unattended,
    Never change any settings in XX,
    Enter minimized mode(reboot),
    verify W7 in XX,
    Come back to attended,
    Clear playlist,
    verify W7 in XX,
    verify Winmgmt in task manager.
All is well for now.  I will keep monitoring.
(I will also check my CPU temp since how XTweaks should be
operational.  Initial check is okay:  I'm running fans much faster
than you on my XXHighEnd PC)
July 2019:
« Reply #3 on: June 24, 2013, 08:04:50 pm »
Good Charlie. In the next version there will be something that hopefully prevents this from happening.
And thank you for your feedback through email.
xp9433
« Reply #4 on: June 25, 2013, 07:07:43 am »
"[/quote] Your DAC: Wyred 4 Sound DAC2 [/quote]"
charliemb, Just wondered if you had been following the discussion on computeraudiophile.com about  the upgraded DAC2 SE?
Frank
Page created in 0.149 seconds with 19 queries.
