November 25, 2024, 05:29:34 pm *
Author Topic: USB going optical  (Read 28764 times)
« on: June 19, 2013, 02:37:53 am »
I read this through CA today. Seems interesting !
http://www.slashgear.com/optical-cables-by-corning-brings-thunderbolt-cables-to-the-budget-crowd-07263926/
The article talks about Thunderbolt, but also USB 3 optical cables.
" If Thunderbolt ports aren’t your thing at the moment, don’t worry because Corning also has full USB 3.0 options available as well. Corning and Optical Cables states Thunderbolt will be available in lengths of 12ft, 18ft, 10m, 30m, 50m and 100m (last is longest available) while USB 3.0 will come in 5.5m, 10m, 15m and 30m. As fart as pricing is concerned, we aren’t sure at the moment. Corning stated that they’ll be releasing further pricing details soon, as well as their respective retail partners. "
« Reply #1 on: June 19, 2013, 10:08:00 am »
I know, this isn't your text Alain ...
swoon
« Reply #2 on: June 19, 2013, 10:31:11 am »
Wink  Now I understand why someone commented "Fart price ?" after...
There are not much details about how it would be implemented, but I hope this involves some kind of isolation against noise from the PC...
It makes me think about the Adnaco... Did yoy have the chance to make some tests with the Adnaco (the S3B if I recall correctly) ?
« Reply #3 on: June 19, 2013, 10:34:13 am »
http://www.corning.com/CableSystems/OpticalCablesbyCorning/where-to-buy/default.aspx#.UcFqRJzgxhE
« Reply #4 on: June 19, 2013, 12:55:37 pm »
No such isolation helps against the noise we talk about.
Let me be ignorant for a while.
You know what ? As soon as someone comes up with a "hey, no single XXHighEnd dial influences anymore !!" ... then you have the isolation you want.
So, who ?
« Reply #5 on: June 26, 2013, 01:35:25 pm »
Well yes.. I mean no Wink The noise incoming through the signal (data) path has to be taken care of - of course... But at least nothing would add "between" components no ?
The noise will always need to be cut from the start, or "filtered"...
« Reply #6 on: June 26, 2013, 02:19:18 pm »
That's what you pray for Alain. But think Adnaco and you get the picture.
Btw, didn't look at the supply at the PC end (when this is about disks), but I think the light won't go in there for free.
« Reply #7 on: June 26, 2013, 02:48:12 pm »
Yes I know... I still read some people seem to praise Adnaco (re: Jplay forum)... Did I or do they miss something ? Unless they are not talking about the S3B...
« Reply #8 on: June 27, 2013, 12:58:44 pm »
Fairly easy answer : because everyone without good reference thinks that when something sounds different, it also sounds better. Placeboes work nicely here.
And for the literal Adnaco : More bass, less sharp highs. Great.
But for people with a more accurate source it comes across as less defined bass and blanketed highs.
Look at that forum, and imagine yourself to be part of it, asking a question like people do here.
No.
Nothing can be trusted there, but no different than anywhere. Phasure really is different and I think it stands out.
And for you Alain, you are the first to understand what I mean because you are so that when you don't hear something or are not sure whether it's consistent, you say nothing. This counts for many here and also for myself.
But this is exactly how all what *is* said in Phasure can be trusted. At least I do and for 100%.
love
« Reply #9 on: June 27, 2013, 01:20:22 pm »
Thanks Peter Happy
Have I mentionned somewhere (I am not sure) that since I felt the sound was not good (with the S3B), I trie connecting it between  my external music hard drive and the PC ? This was an attempt to make it useful... But I finally agreed that it was not (useful for me), so I decided to return it...
I had always tried to apply the simplest path between 2 components, but nowadays (with the SMPS), it can get complicated...
From what I see now, a "almost perfect" decicated music PC should have different power supplies, have a simpler operating system, isolated sections (physically and electronically)... Maybe 2 CPUs - one for peripheral operations and one aimed at audio and audio only ?... I am thinking loud...
But to "all" have the same pc could be a nice thing... Even if I feel this would be controversial...
Jud
« Reply #10 on: June 27, 2013, 05:21:23 pm »
The Adnaco I guess has a PCIe card and a wall wart; it appears the Corning will be bus powered.  I hope the Corning is cheap enough to be in "Heck, let's try it" territory, though at least at first I'm not optimistic.  (The ads for it appear to be aimed at the pro market, A/V productions studios, etc.)
Latest I've seen on availability is 3rd quarter 2013, which is now, so we'll see....
« Reply #11 on: June 27, 2013, 05:26:17 pm »
LOL Jud, imagine me thinking that USB bus power isn't possible because that won't go through glass. But I never thought about power from both (USB bus) sides ...
fool
But still. All we do these days (OK, I am) is preventing such things. That too will imply noise.
So, not much different than people externally powering USB disks and such (never mind this is the PC side and not the DAC side).
« Reply #12 on: June 27, 2013, 07:03:25 pm »
The benefit of an optical USB-cable is that it breaks the ground loop between PC and DAC/Hi-Fi. This is good news, especially for those with wideband transistor amps. The bad news is that in each end of the optical cable, there is an opto-converter driven by typical switch mode wall warts, which themselves introduces distortion. So, in this field there is no guaranty for success.
Jud
« Reply #13 on: June 28, 2013, 01:19:57 pm »
I wonder about whether there is a wall wart in this case.  From Corning's FAQ:
Do Optical Cables by Corning require external power?
Optical Cables by Corning are powered directly from the host and peripheral devices. No external power adapter or injector is needed. NOTE: Optical Cables by Corning do not provide or transmit power to devices.
« Reply #14 on: June 28, 2013, 02:26:31 pm »
No of course there is not. But not everybody reads all (hi Pedal) and not everybody's brains work at full throttle always (hi PeterSt).
What I wonder though is how this will/can work on low powered USB ports. I do this by heart :
150mA is normal and I don't think it will be sufficient for this application.
600mA is "extra" and if you'd ask me, designed for charging devices - even when the PC is shut off (but power switch still on). This should be sufficient for this application or otherwise nothing works.
But it is the very first I shut down (BIOS) because no way I will allow 600mA spikes by any by accident requiering device.
If you understand this, you also understand why in my view such applications (also USB powered disks) never work (out). Only "no power" is OK. Like the NOS1. But now there's a normal linear supply in there and regulated such that (hopefully) it is harmless. And STILL any optical to electrical conversion implies current spikes we don't want.
Hey, it is all not soo easy ..
haha
Page created in 0.139 seconds with 19 queries.
