April 05, 2025, 05:14:51 am *
Author Topic: Tweaking PC again or sqeezing the orange dry  (Read 7490 times)
listening
« on: June 02, 2013, 08:09:59 pm »
After reading a lot of posts about XXHighend and Window 8 (will install a version next week) and not prepared to invest in new PC hardware I tried some additional Mobo/BIOS tweaks:
Tweaking down the CPU clock rate again
I found some aditional parameters in the BIOS originally built in to overclock the CPU but used them to lower the clock rate. Hopefully I have reached the same low level as Peter.
Tweaking down the clockrate of PCI
Done via BIOS to the lowest possible value
Tweaking down the clock rate of the North-Bridge
Done via BIOS to the lowest possible value.
The early sonic results are very promising.
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: June 02, 2013, 09:09:15 pm »
Georg
Hi Georg,
I know that there is some underclocking done through Xtweaks, but to reduce more has got to be done from BIOS...
Peter, how do you explain the results of a reduction in clocking ?
Thanks.
listening
« Reply #2 on: June 04, 2013, 10:54:54 pm »
Hi Alan,
you've got to have the right feeling for it and I'm not sure to reach a stable point. Actually I've set the CPU clock rate, the Northbridge clockrate including the PCI clockrate to the same low internal frequency. The Hypertransport bus (AMD specific) is set to maximum clock frequency.
The influence of this settings is lower than other XXHighend parameters. But I will try further to get the best out of the system  Wink  Maybe there is a bigger advantage with Windows 8.
Georg
-> SMSL SU-8 ES9038
« Reply #3 on: June 05, 2013, 12:26:44 am »
Hi Georg,
The problem I have is that there are so many parameters with strange acronyms (there is not "Northbridge" notion in the BIOS for this pc), I fear I would do something that would screw up and then be forced to reset everything. I may have to go through experimentation at a certain point, but like you mention, I am not "in it" (curious yes, but not in a hurry) for the moment.
