November 23, 2024, 02:42:18 am *
Pages: 1 2 [3]  All
Author Topic: Windows7/8 Dual Boot (etc.)  (Read 40916 times)
« Reply #30 on: June 04, 2013, 07:00:45 pm »
I may have a ram instead of a rom as memory Wink
Jud
« Reply #31 on: June 04, 2013, 07:59:33 pm »
Well, I think XXHighEnd is "stable" now on the Minimized OS and needing a Restore Point for whatever reason. I mean, I don't think people ever need it for that reason.
But there can be other reasons of course. And when you need your Restore Point while it has gone, this is not nice.
Your W8 Restore Point disappears as soon as you even look at one of the other boots (including Repair - nice !).
Got it.  So quick followup question: Is this only between Win OSen?  Because Win7 can go away on my desktop as soon as I hear Win8 sounding the same or better.  But I would like to be able to use Linux and FreeBSD without having an additional concern.  I have backups on a schedule (happens while I'm away at work) so there wouldn't be data loss to any significant degree, but just the time and aggravation factor.
« Reply #32 on: June 04, 2013, 08:24:41 pm »
Jud, I can't tell. But typing BCDEdit /enum in an elevated command prompt (in Windows) should tell you enough. If you there see all OSes passing by, I guess the problem will be no different.
Actually, nah - I can't imagine. But still.
Internet won't bring you much luck either. At the time (last February I think) the problem of disappearing Restore Points was known, but the cause was not. I found that out myself (and Google may bring you my own posts about it).
Btw, for Windows it's a matter of not letting the OS see the drive of the other OS (there's Registry hacks for that).
Jud
« Reply #33 on: June 05, 2013, 12:50:13 pm »
Well, if the choice is between multi-booting and using XXHE with restore points intact, I guess you know which way I'll go.  See all of you, it's been nice.
Yeah, right!!!
 teasing
« Reply #34 on: June 05, 2013, 05:39:08 pm »
I don't care much.
Because I will allow any Restore Points to be deleted; I just know when that will happen, and will recreate one later. naughty
« Reply #35 on: June 05, 2013, 07:50:38 pm »
Suddenly answers seem to take much place with so few words ?
Wink
« Reply #36 on: June 05, 2013, 09:09:03 pm »
Typically Dutch Alain.
Or American. I'm not sure about that yet. Happy
Jud
« Reply #37 on: June 05, 2013, 10:12:09 pm »
Wink
Return/Enter key problems.   innocent
Stanray
« Reply #38 on: June 07, 2013, 05:21:07 pm »
Thank you all for your time and advise.
It seems time and experiences have caught up on me and I decided to skip the dual boot and installed W8 only. It seems to work ok (nice to see W8 disguised as W7). Serious listening will start this weekend.
Stanley
Pages: 1 2 [3]  All
