November 22, 2024, 10:46:31 pm *
Pages: 1 [2] 3  All
Author Topic: Windows7/8 Dual Boot (etc.)  (Read 40905 times)
Stanray
« Reply #15 on: June 03, 2013, 11:55:16 pm »
Thanks all for the input.
I burned an ISO DVD according to one of the mentioned tutorials, but this disk reacts the same as my official W8 DVD.
Then I tried the disks in another W7 pc (my laptop) and guess what: the dvd's boot up perfectly. No problems here!
So it must be something else and I think it's related to *Legacy* and *UEFI* boottype (which I don't understand yet).  scratching
Any ideas?
Stanley
« Reply #16 on: June 04, 2013, 12:27:05 am »
Hi Stanley,
First disable Minimize OS in XXHighEnd, don´t forget it because frequently we start to make changes with this Minimize OS active and that is impossible, restart and after that and when all is done put the W8 DVD in the CDRom try, restart again and while restarting click repeatedly the key delete, that enters you to the BIOS, there go to EXIT and click on Load Setup Defaults, this is just in case you have modified something previously. Then go to BOOT, there you will find 1st Boot Device, 2nd Boot Device, 3rd Boot Device. With the arrows mark 1st Boot Device and click Enter in your keyboard, a window opens where you have in bold letters the Boot Device you have active now to boot your pc, ok move the arrows until the bold letters are ATAPI CD-ROM (or similar), then click Enter again. Click F10 and Ok (Save configuration changes...).
Now it is supposed that your system will start from your CD Rom (W8 DVD). Then follow the steps from the link I sent you yesterday to install W8 in a partitioin. http://www.buildeasypc.com/sw/windows_8/install_windows_8.htm. To create a partition to install W8 take special attention to steps 8, 9, 10 and 11.
Let me know how it goes and if you find a problem
« Reply #17 on: June 04, 2013, 08:24:25 am »
Or if you go the "Win7 Download Tool" route, you can avoid wasting any DVDs at all, as well as the step to extract from the iso IIRC, by using the "Download Tool" to make a bootable iso from a USB stick (must be 8GB or more, again IIRC).  That's the way I did it, and had no problems.  Goes faster than a DVD, especially with USB3 if you have a capable port and stick.  Probably one of Juan's tutorials describes this method, or if it does not, there are such tutorials on the web.
Jud,
Assuming you meant to say "make a bootable USB stick" ... I would personally never advise that to people who don't make a daily job out of these things (so to speak). When this works the first time you are or lucky or have a mobo/BIOS which has been made very (very) explicitly for the job. I mean, even when it already worked, it can take me a plain half of an hour to let it boot again after some mangling. Example in my case : when you take out all of your disks to be sure you won't be formatting a wrong one (inserting disks hot-plugged back in later), it will never boot when the status is not "boot from USB" already. Never. This is because it can only detect the thing in a live (OS) system. So, plugging in the stick when the PC is off and think it will boot from the stick - no way (unless it booted last time from there). It is just not seen in the BIOS in that situation.
... not in my PC ...
And thus, when you are not sure whether your boot medium is bootable in the first place, this is not the way to go of course. But sure, once you have done it before and you know your workflow is OK, then it's a matter of mangling till it works.
« Reply #18 on: June 04, 2013, 09:21:42 am »
That's the way I was successfull too. My music PC has no optical storage devcies.
I keep the install-usb for mobo and OS drive updates. I store the motherboard drivers in a separate driver directory.
Easy as pie, even I can do it!
regards, Coen
regards, Coen
stefanobilliani
« Reply #19 on: June 04, 2013, 10:44:18 am »
In my experience the bootable USB stick is handy *when* you explicity want to boot in UEFI . Not all DVD's are make up for UEFI , even the ones that comes from the Windows Upgrade tool . Moreover , if your motherboard is set up for a Windows boot loader , and *not* a legacy OS , that is when your mobo will not see the DVD somehow .
There is also a way to format the USB stick in FAT 32 by the command prompt ( terminal ) and copy all the files of the DVD into it with explorer , and obtain that way a UEFI bootable media , without the W7 tool .
S
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
Jud
« Reply #20 on: June 04, 2013, 12:57:32 pm »
Have a reasonably old mobo, *not* UEFI (Asus Formula III Rampage), and the stick install worked like a charm first time, so my experience mirrors Coen's rather than Peter's.  (The BIOS does let me boot from a USB device.)
But I do have a fair number of years of experience in both multiboot arrangements and USB stick installs, so it wasn't anything new or scary.  A big reason it wasn't scary is that I *always* have at least one backup ready, a lesson from painful experience.  That way it's just aggravation (time) rather than disaster (lost stuff).  In fact I recently managed to accidentally erase my main external music drive but was able to restore nearly everything from a backup, though it's taken some time.
« Reply #21 on: June 04, 2013, 02:38:33 pm »
My experience in this matter is quite nonexistent. I have made some dual boots a long time ago.
With all that is possible nowadays, I have decided to have a different drive for each OS. Of course, this can be done only whenever feasable, affordable and practical.
I use SSD for the OS. It is "standard" for me to expect quick boot and quick access to any program. I can also afford to have all my drives external.
Each OS stands on its own SSD. I just have to swap the connection between one drive or the other.
Not that this is economical nor practical for everyone of course, but it can be another avenue...
« Reply #22 on: June 04, 2013, 03:33:35 pm »
At the end the only OS that we´ll use will be W8, it looks that Peter is not going back to W7 and all the upgrades of XXHighEnd will be done for W8. So this dual boot configuration is only for the purpose to make some momentary comparisons between the two OS. That's at least what it seems.
Jud
« Reply #23 on: June 04, 2013, 03:46:12 pm »
I know, and since my MacBook Pro laptop in the main system is only W7-capable with Boot Camp, I will have to do something in a year or two at least: a newer MBP, or a PC music server.  The latter would I think be much less expensive.  Because there is also Mac software I like, I would want to build it as a "Hackintosh," and why not throw in Linux as well?  (See, multi-booting, so almost on topic!)  An interesting project, but not for the immediate future.
« Reply #24 on: June 04, 2013, 04:56:21 pm »
Yes, but people must be careful that they don't make a Dual Boot of *that*. I mean, once you set this up from within the other OS, you will just have that. This is tricky, because the BCD Store will not be on both disks. And of course at one time it is on the one not in the system. And now the other won't run too anymore (can be repaired, but this is not so easy).
So, this is just the warning that a pair of swappables disks is very OK, but it should NOT be Dual Boot as such. Dual Boot is something different and it can be done with two disks just the same.
« Reply #25 on: June 04, 2013, 04:58:32 pm »
And of course there is the story that when you boot Windows 7 on a Dual Boot with Windows 8, you will loose your Restore Points from Windows 8.
Can be fixed ahead of disaster, but this really doesn't go automatically.
Jud
« Reply #26 on: June 04, 2013, 05:08:40 pm »
Oh.  Thanks for the warning, as I'll be installing XXHE on Win8 soon on the desktop where I have a dual boot.  So if I have a restore point in Win 8, I want to be sure to reboot to Win 8, or...?  I haven't noticed any problems with XXHE on a minimized Win 7 and dual booting with Win 8.
« Reply #27 on: June 04, 2013, 05:49:26 pm »
Well, I think XXHighEnd is "stable" now on the Minimized OS and needing a Restore Point for whatever reason. I mean, I don't think people ever need it for that reason.
But there can be other reasons of course. And when you need your Restore Point while it has gone, this is not nice.
Your W8 Restore Point disappears as soon as you even look at one of the other boots (including Repair - nice !).
W7 has the same behavior towards XP (and Vista ?) but less "hard". Actually it is a feature, though very hard to grasp, especially when you are in troubles.
And getting your "F8" operable in W8 is just that other thing. Can be done too, but by default it is nowhere - especially when you do NOT have a Dual Boot. Haha.
« Reply #28 on: June 04, 2013, 06:15:18 pm »
Ah... You helped me remembering what this was about (the restores that were lost) because of some interaction between W7 and W8...
I think I understand about a combination of dual-boot and 2 different physical drives... Bur of course, you know that this is not my case... They really are totally independant.
« Reply #29 on: June 04, 2013, 06:23:31 pm »
Oh, you actually forgot eh ? Well, I recall a full Sunday afternoon chatting full a topic with you. For you it will have been morning though. Haha.
shout
Pages: 1 [2] 3  All
Page created in 0.115 seconds with 19 queries.
