Stanray
« on: June 02, 2013, 06:04:15 pm » |
Hi Stanley, all my music hdd are SATA and I use the external boxes to convert SATA to USB 3.0 to connect it to the mb. Sorry, I have to update my signature.
I post some pictures here and in I'VE BUILT MY NEW PC FOR XXHIGHEND AND ... with the USB 3.0 boxes, the Anti-vibration discs, etc
Best regards, Juan
Muchos gracias Juan. I ordered the converter from the Spanish Amazon site. Tonight I will install 09z9b. For now on W7, as I didn't succeed in making a dual boot W7 and W8 configuration (pc won't boot on W8 DVD for some reason). Best wishes, Stanley
« Reply #1 on: June 02, 2013, 08:01:36 pm » |
De nada Stanley (you are welcome) Someone else asked (PM) about how to install W8 and W7 for dual boot and I sent him this link http://www.labnol.org/software/install-windows-8-dual-boot/20939/You can also find there some links that could help you also to solve your problem with your W8 DVD. Would be a good thing if you could install W8 so you can compare it with W7 and test it with the best settings for each one and see if really W8 and 09-z9 is a good match or not. Best regards, Juan
« Reply #2 on: June 02, 2013, 08:11:22 pm » |
Hey you both,
Someone asked to stay on topic. I did not disagree (or otherwise I would have said so).
So I split this from wherever it was not liked much. But sure continue here if you like.
« Reply #3 on: June 02, 2013, 09:05:46 pm » |
« Reply #4 on: June 02, 2013, 09:16:29 pm » |
« Reply #5 on: June 02, 2013, 10:27:26 pm » |
haha
« Reply #6 on: June 02, 2013, 10:58:31 pm » |
Jud
« Reply #7 on: June 03, 2013, 01:26:33 am » |
Stan, did you change the BIOS setting to boot from disk when you tried to install from DVD?
Win 7 64-bit; i7-950@3.07GHz; 16GB RAM; OS on SATA 6GB/s SSD; AIFF files on external FW HDD; XXHE and Playback Drive on separate RAMdisks; no page file; Audioquest Dragonfly DAC/preamp; PSE Studio IV amp; Pioneer SP-BS22-LR bookshelf speakers or Etymotic Research ER-4P in-ear monitors. XXHE 0.9z-8-3a settings for the moment: Peak Extend; Arc Prediction; Redbook files upsampled 2x; KS Adaptive Mode; Phase Alignment off; buffer=512; Straight Contiguous; Playerprio=Low; ThreadPrio=RealTime; Unattended; OS minimized; all services off; Q1=17, factor=2; SFS=2.1; XXTweaks=Ultimate; Time Performance Index=Not the best.
« Reply #8 on: June 03, 2013, 09:09:51 am » |
Could you change the name of this topic to "How to install W8 and W7 for dual boot" or something similar?. Now it seems hard to know what it is about. Or maybe is Stan who has to change it as he is the first one in the thread.
Thanks, Juan
Stanray
« Reply #9 on: June 03, 2013, 09:56:15 am » |
Thanks, Juan
Good plan Juan, thank you. Possibly others might run into questions about W7/8 DB. I will try to install a W8 dual boot later this week when I have time and will report back. Stanley
Stanray
« Reply #10 on: June 03, 2013, 03:57:09 pm » |
Hi Jud, Yes, in the BIOS I set the DVD-drive as the first device in the boot order, but this is ignored and W7 keep starting up. *In* W7 however, the DVD-drive works OK and I can start the W8 setup (which is not what I should want). Stanley
« Reply #11 on: June 03, 2013, 04:19:50 pm » |
Stanley
Hi Stan, You have an upgrade version of W8 (from W7 to W8) or it is a W8 dvd to make a clean installation? This is the tutorial I followed to install W8, there you can find also links on how to make a partition to install it: http://www.buildeasypc.com/sw/windows_8/install_windows_8.htmRegards, Juan
« Reply #12 on: June 03, 2013, 04:25:41 pm » |
Stan, see also this tutorial, it is a very good one also, try to read both tutorials, sure you´ll find a solution to your problem: http://pcsupport.about.com/od/windows-8/ss/windows-8-clean-install-part-1.htmHere is a list of Windows 8 tutorials, these are tutorials about how to install Windows 8 and other different related issues, nothing related with XXHighEnd. For Windows 8 and XXHighEnd follow Peter´s tutorials. http://pcsupport.about.com/od/windows-8/windows-8.htmJuan
« Reply #13 on: June 03, 2013, 04:52:11 pm » |
If you downloaded this from MS etc. ... that version is NOT bootable (I am talking about a normal base version). You can make it bootable with the "Windows 7 Download Tool" (never mind its name - and download that first). But before you use that you must extract the .iso, so you will see normal files in there. The output of the "Download Tool" must also be normal files. Of course this is a bit of a stupid hassle because you first must make that bootable file set, and burn that to DVD again. I wasted 5 or 6 DVDs before I understood what was all wrong and what to do. You can stick to one wasted DVD if all is right. Hope this helps, Peter
Jud
« Reply #14 on: June 03, 2013, 10:06:45 pm » |
Or if you go the "Win7 Download Tool" route, you can avoid wasting any DVDs at all, as well as the step to extract from the iso IIRC, by using the "Download Tool" to make a bootable iso from a USB stick (must be 8GB or more, again IIRC). That's the way I did it, and had no problems. Goes faster than a DVD, especially with USB3 if you have a capable port and stick. Probably one of Juan's tutorials describes this method, or if it does not, there are such tutorials on the web.
