April 05, 2025, 06:03:41 am *
Author Topic: With mp3 tracks are skipped  (Read 13057 times)
Flecko
« on: June 02, 2013, 03:47:20 pm »
I found a minor bug. If a mp3 file is played, it can happen, that the track ends suddenly and the next track starts. I used SFS 12. After increasing to SFS 120 the errer didn't occure anymore.
Greetigns
« Reply #1 on: June 02, 2013, 04:10:16 pm »
Adrian - So with SFS = 12 you can copy this behavior ?
And with tracks from more than one album ?
Flecko
« Reply #2 on: June 02, 2013, 04:46:51 pm »
I will try some more mp3.
Flecko
« Reply #3 on: June 02, 2013, 05:39:12 pm »
The prolem occures upto now only with 320 kbit mp3 but with different albums. Increasing SFS from 12 to 120 "solved" the problem again. I couldn't provoke this error with lower bitrates but I do not say that this cannot happen. For that, the test time was to short.
« Reply #4 on: June 02, 2013, 05:48:16 pm »
Ok, please FileMail me such an album, and tell me which track I can try.
Attended or Unattended ?
Regards and thanks,
PS: And this never happened before ? (I know about your upsampling capabilties now).
Flecko
« Reply #5 on: June 02, 2013, 07:27:51 pm »
I send you two files. It is the second track I have in the playlist when the skipping begins. After that, every tracks will only play some seconds (~20s) as I just found out.
It happens in unattended mode.
I had a lot of problems with earlier versions and things like this happend. But since 9z8.3 and 9z9bx I have no problems anymore, except this one. I think this is SFS related because it disapears when I increase SFS.
charliemb
« Reply #6 on: April 23, 2016, 06:20:45 pm »
Hi Peter
This is a reply to a post from June 2013.  In version 2.01,  I encounter this also with 320 Kbps mp3 and only in unattended mode.   To listen to 320 K mp3 I have to listen in attended mode.
I would say this is not urgent for me.  Nor would I ask you to put significant amount of time fixing it.  I can always listen in Attended, as mp3 losses even at 320 are far greater than what is lost in Attended mode (say my ears);  and also I rarely listen to MP3.
Charlie
July 2019:
« Reply #7 on: April 23, 2016, 07:13:46 pm »
Hey Charlie,
Nah, this has been solved BUT is back again in a bit of a different way. I run into it some times myself, but I always forget to put it into my ToDo.
But doing that now !
« Reply #8 on: April 28, 2016, 08:33:54 pm »
Today I was listening to a mp3 album in XXHE 2.02. Every track was ending before the real end of the track in unattended mode. When I switched to attended all was working ok.
Regards Johan
« Reply #9 on: April 29, 2016, 08:20:20 am »
Thank you Johan.
And yes, it is exactly that. Btw first track is always fine, I think.
I will solve it.
« Reply #10 on: May 28, 2016, 12:28:50 pm »
This is solved in 2.06.
