November 23, 2024, 06:00:41 am *
Author Topic: Disabling Virtual Memory can cause errors  (Read 13414 times)
« on: November 12, 2007, 02:29:15 pm »
I think the disabling of Virtual RAM was the tweak that fixed it
On a regulare base I had memory errors during XX usage. At a certain moment I was realizing that I had disabled the Virtual ram. Tweak from the past : http://imageevent.com/cics/v03theartofbuildingcomputertrnsp;jsessionid=t9hii13rc1.zebra_s
After enabling the Virtual RAM the memory problems are gone! So be aware of memory errors!
Regards, Johan
« Reply #1 on: November 13, 2007, 06:08:13 am »
G'day Johan  smile
I'm not fully understanding what you are saying here. If you are implying that you had 'memory errors' when you disabled virtual memory and that all was fine after you re-enabled it, that would only indicate that you had insufficient physical RAM memory available for your systems needs. If these 'memory errors' were caused by a physical defect in the RAM chips themselves then these errors would be evident regardless of whether virtual memory was enabled or not.
For my part, I haven't experienced a single glitch or stutter since disabling virtual memory several days ago. I am now confident I have solved that issue  yahoo
Cheers smile
« Reply #2 on: November 13, 2007, 09:07:53 am »
Hi Russ,
Indeed, after the re-enabling of the virtual memory I've not seen any memory errors in a week. For me it solved a problem.
Johan
« Reply #3 on: November 13, 2007, 09:10:04 am »
Can you be more precise on "Memory error" ?
« Reply #4 on: November 13, 2007, 10:25:52 am »
See http://www.phasure.com/index.php?topic=184.msg1145#msg1145
Johan
« Reply #5 on: November 13, 2007, 11:12:24 am »
But Johan, something is not right here;
Although it would (at last) explain the "errors" you referred to in the other thread, the screen shots you have in there show virtual memory being present ("wisselbestand" = paging file) ...
Anyway, if this is what you mean, obviously you just ran out of physical memory.
« Reply #6 on: November 13, 2007, 12:12:32 pm »
I have test it again. Disabled the usage of virtual memory and did a reboot of the system. See the screenshots. I don't understand the reason but you can still see the usage of virtual memory (wisselbestand=...)
« Reply #7 on: November 13, 2007, 12:29:56 pm »
Ah, I see. So that's the physically allocated disk space then (currently used or not). But look at the bottom of the first screenshot. It says "Currently allocated : 0".
Thanks Johan.
« Reply #8 on: November 13, 2007, 12:41:50 pm »
Remember, you should have memory space of (around) 500MB for Vista itself, plus 3 times the filesize of the largest track you play (can be 2 times only, depending on "situations"). Two subsequent tracks at full CD length would be a no go (but who has that secret).
Note that this "rule" does not incorporate the disabling of virtual memory. It's up to you now to find the limits, or better : up to your Vista (generally you are not the boss in there).
« Reply #9 on: April 07, 2008, 02:07:27 pm »
Hmm ... Today I tried to switch off the paging file of myself. It appears to be impossible ...
To me it looks like that the OS will always be using it for itself. "Itself" does not mean XX, because when XX needs it, it errors (out of memory).
