April 05, 2025, 06:53:30 am
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
News
August 6, 2017 : Phasure Webshop open !
Go to the Shop
Home
Help
Search
Login
Register
XXHighEnd
Ultimate Audio Playback
Your thoughts about the Sound Quality
Windows 8 and 09-z9, a match made in heaven?
Pages:
1
2
3
4
5
All
« previous
next »
Author
Topic: Windows 8 and 09-z9, a match made in heaven? (Read 68033 times)
Re: Windows 8 and 09-z9, a match made in heaven?
Reply #60 on:
June 27, 2013, 07:38:46 am »
Hi Guys,
Started XXHE & Playback drive on IMDisk. There is improvement in the musical qualities of the sound, however its still not as good as 0.9z-7-5.
Q1 setting of 14 sounds better than 30 with IMDisk.
Peter, a question on the filing system of the IMDisk drives, is NTFS ok?
Reply #61 on:
June 27, 2013, 09:00:12 am »
Hi Arvind,
I have to agree with you, again!
Regards, Coen
Reply #62 on:
June 27, 2013, 10:09:31 am »
Arvind, I use exFAT. I don't know whether that matters. I just use it.
Btw, my Q1 is 14 and xQ1 is 10. Maybe you forgot to tell about xQ1, because I have in my mind that I told you my settings because you aksed.
But maybe it was someone else.
W10-14393.0
- July 17, 2021 (2.11)
XXHighEnd Mach III Stealth LPS PC -> Xeon Scalable 14/28 core with Hyperthreading On (set to 14/28 cores in BIOS and set to 10/20 cores via Boot Menu) @~660MHz, 48GB, Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/0/0/*1*/ Q1Factor = *4* / Dev.Buffer = 4096 / ClockRes = *10ms* / Memory = Straight Contiguous / Include Garbage Collect / SFS = *10.13* (max 10.13) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / OSD Off (!) / Running Time Off / Minimize OS / XTweaks : Balanced Load = *62* / Nervous Rate = *1* / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Custom Filtering *Low* (16x) / Always Clear Proxy before Playback = On -> USB3 from MoBo -> Lush
^3
A: W-Y-R-G, B: *W-G* USB 1m00 -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4b (16ms) -> B'ASS Current Amplifier -> Blaxius
*^2.5*
A:B-G, B:B-G Interlink -> Orelo MKII Active Open Baffle Horn Speakers. ET^2 Ethernet from Mach III to Music Server PC (RDC Control).
W10-10586.0
- May 2016 (2.05+)
*XXHighEnd PC -> I7 3930k with Hyperthreading On (12 cores)* @~500MHz, 16GB, Windows 10 Pro 64 bit build 10586.0 from RAM, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.10 (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / All Services Off / Keep LAN - Not Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *43* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / -> USB3 *from MoBo* -> Clairixa USB 15cm -> Intona Isolator -> Clairixa USB 1m80 -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (4ms) -> Blaxius BNC interlink *-> B'ASS Current Amplifier /w Level4 -> Blaxius Interlink* -> Orelo MKII Active Open Baffle Horn Speakers.
Reply #63 on:
June 27, 2013, 11:18:17 am »
Quote from: arvind on June 27, 2013, 07:38:46 am
XXH is very complicated with all the different settings possible. It is very easy to loose focus of the "right SQ" and therefore a reference system is mandatory. The SQ of 0.9z-7-5 was very irritating and I connected a CD player (Studer A730) to my system again. Release 0.9z-7-5 sounds with my settings dull and muffled, no sparkling of the cymbals etc.
The SQ of 0.9z-9b with W8 is meets my preferences at best.
Reply #64 on:
June 27, 2013, 11:31:58 am »
Quote from: PeterSt on June 27, 2013, 10:09:31 am
Since default filing system is NTFS, I just left it that way. Probably does not matter.
xQ1 is 10 in my case too. Rest is same as my sig.
Pages:
1
2
3
4
5
All
« previous
next »
Please select a destination:
=> Download Area and Release Notes
=> Getting Started and further Tutorials
===> Why XXHighEnd
===> Getting Started
===> Coverart
===> Sound Quality XXHighEnd Related
===> Sound Quality OS Related
===> Remote Control
===> Scaling and Skinning
===> Galleries
===> Settings General
===> The Operating System booted from RAM
===> Windows 8 / Windows 10 Tutorials
===> Streaming Services
===> Useful Topics (add yourself !)
=> XXHighEnd Support
=> Your thoughts about the Sound Quality
=> Music Storage and convenient playback
=> Interesting Music / Testmaterial
=> Playback Tweaks and Source related subjects
=> Your questions about the PC -> DAC route
=> Phasure NOS1 DAC
=> XXHighEnd PC
=> Orelino / Orelo MKII Loudspeakers
=> Cables (Community induced)
=> Chatter and forum related stuff
