November 23, 2024, 12:25:06 pm *
Author Topic: 09-z9: Volume 30 db lower with 24 bit only  (Read 18511 times)
listening
« on: May 30, 2013, 06:35:01 pm »
when using 24 bit only mode (waveIO card) it is necessary to increase the digital volume 30 dB. Peak extension is off. Is that intended?
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: May 30, 2013, 07:18:00 pm »
Uhm Georg, I don't think so !
Could be a nice "wife's" feature though.
I suppose this worked OK pre 0.9z-9 ?
listening
« Reply #2 on: May 30, 2013, 07:35:59 pm »
Yes, it worked. Maybe it's a problem of the Thesycon driver - I will check.
Georg
-> SMSL SU-8 ES9038
« Reply #3 on: May 30, 2013, 07:50:05 pm »
Well, I don't know. I just came back here to say :
One small-ish problem : here it works.
I tried all possible input-output combinations up to 192KHz input and 384KHz output and all looks fine.
For Kernel Streaming that is. With WASAPI nothing seems to work at all (error messages). But that could/should be the NOS1 ... (?) I must check that, because I never tried the Needs 24 bits really for WASAPI, I think.
« Reply #4 on: May 30, 2013, 08:19:17 pm »
When I first tried 0.9z-9 before activating, the output was very low (maybe 30dB lower than normal), even when the volume control was set to a regular listening value. As soon as I activated, the output increased to normal, without my touching the volume control at all. And all has remained well since.
HTH.
« Reply #5 on: May 30, 2013, 08:21:46 pm »
Now *that* will be the day !
I guess I have to believe you, but it is difficult. Happy
Thank you Mani.
So Georg, are you Activated by chance ?
« Reply #6 on: May 30, 2013, 08:22:58 pm »
And Mani, I suppose this is unrelated to the Needs 24 bit setting ?
« Reply #7 on: May 30, 2013, 08:56:25 pm »
Well, it never happened to me before. I was shocked that I was getting such little output at a regular volume control setting and was going to post something about it. But after the activation, everything was OK, so I didn't bother.
Yep, totally unrelated.
« Reply #8 on: May 30, 2013, 09:10:51 pm »
Well, you won't believe it, but just minutes ago I was trying something on a laptop. Just a testsignal - see whether it worked for a certain setting. Of course I started with putting 0.9z-9 on it first.
Gently pulled the volume wheel, ... and what do you think what happened ?
swoon
« Reply #9 on: May 30, 2013, 09:18:49 pm »
What ? no quick answers ? OK, hint : it was not Activated.
« Reply #10 on: May 30, 2013, 09:26:54 pm »
Still no answers ?
All right. Another hint : I did not think about this topic/issue at all. fool
Some on now ...
« Reply #11 on: May 30, 2013, 09:32:03 pm »
It really doesn't matter what and how many hints I give eh ?
Ok ok ok, the sound was real low. Not that I really could tell from the 1x1cm speakers in there, not even stopping the normal music playback going on at the time (it now is again), but anyway.
So ...
« Reply #12 on: May 30, 2013, 09:36:18 pm »
... So I will honestly admit that I forgot to higher the volume which by default is set at -43.5dBFS.
So, not suggesting anything. Really not. Just having a bit of fun because this really happened. And indeed I dit *not* even think about this topic.
So I must be ignorant at least !
PS: But this sure was a non-Activated version. So scratching.
listening
« Reply #13 on: May 30, 2013, 10:54:32 pm »
I believe that xxhighend is activated - but I will take a look again. I found another abnormal interaction with the Thesycon driver. There is a small tool to interactively parameterise the driver. It's possible to change the volume - and it was changed. Seems that there is sometimes unexpected interaction ...
Georg
-> SMSL SU-8 ES9038
« Reply #14 on: May 30, 2013, 11:14:34 pm »
Georg, sorry for all the fooling around by me. And for Mani too : just kidding.
But do you mean that something can change those (volume ?) parameters, or that XXHighEnd might be doing that ?
Anyway I would not know how that should happen.
Windows volume - Yes !
So maybe concentrate on that ?
