November 23, 2024, 10:21:36 pm *
Author Topic: Check Playback Structure msg  (Read 8289 times)
« on: May 29, 2013, 08:24:40 pm »
I fist installed 09-z8a on an i5 laptop and that works fine in full os and minimised. No problems.
I then installed 09z-9 and with settings identical to 09-z8a it does not work I get "Non Covered for playback situation!". So it will not work in Attended and it will not go into minimised.
« Reply #1 on: May 29, 2013, 08:45:52 pm »
Paul,
That "Minimized" can't be related to the same problem. Maybe open a new topic for that with some more specifics ?
Otherwise, what is your input sample rate and bit depth, and what's the output ?
N.b.: This is a typical problem as mentioned in the Release Notes, and now I need to know exactly about the formats.
« Reply #2 on: May 29, 2013, 08:57:23 pm »
DAC Needs is also important. And Filtering Type (AP etc.).
« Reply #3 on: May 29, 2013, 09:26:32 pm »
OK the DAC is simple NOS based on TDA1543 I am running it at 16/44 so filtering is not selected. Buffer size is 512. These settings work OK on 09-z83a
« Reply #4 on: May 29, 2013, 09:34:43 pm »
So ... 16/44.1 -> 16/44.1 is not working. Correct ?
I was afraid of that (see Release Notes). Now I must dig up my Audio Note - haha.
« Reply #5 on: May 29, 2013, 09:35:26 pm »
And some interface.
Bweh.
« Reply #6 on: May 29, 2013, 09:40:31 pm »
I just checked Minimize OS - if I start the laptop in full os, open XX and press "Minimize OS" it will go to minimised o/s no problems.
However if I first try to play music getting get the "Non covered..........." msg then I cannot subsequently go to minimised I get an error msg.
Page created in 0.114 seconds with 19 queries.
