November 24, 2024, 09:16:53 am *
Author Topic: 09-z9 with W8: Alt+S sometimes turn off totally XXHE.  (Read 9909 times)
« on: May 27, 2013, 06:06:03 pm »
With 09-z9 and W8 when I hit Alt+S sometimes turn off totally XXHE.
It happens at Minimize OS and Unattended.
« Reply #1 on: May 27, 2013, 06:11:44 pm »
Hi Juan - Do you really mean Unattended here ?
If so, I don't understand what you mean. XXHighEnd is not even running in that case. So ?
« Reply #2 on: May 27, 2013, 06:20:17 pm »
Ok sorry, although Unattended is active I first hit Alt+X to bring the monitor active and later I hit Alt+S to stop playing. A couple of times and only a couple of times (it never happen in W7 anyway) XXHE was turned off totally.
« Reply #3 on: May 27, 2013, 06:27:16 pm »
Ah, ok. I think this can be "done" in W7 just the same. It is a bit a matter of how the state of all is. I forgot the situation(s), but something like hitting normal Stop can do this too (in W7 at least).
But as a general (to me) known issue, I will look into it.
Btw, it would be a good thing that you explicitly confirm (again ? haha) that whatever it is you do, *never* happened in W7 but now easily in W8. That would be a sort of odd.
And do you use the W7 Shell ? (it can't matter I think, but I do).
Lastly : Only with Alt-s, and never with using the Stop button by mouse ?
« Reply #4 on: May 27, 2013, 06:38:40 pm »
- I do not remember it happened in W7 that´s all can I say ("Never say never again", remember? haha).
- It do not happens easily in W8, only a couple of times in maybe 50 times so far.
- It happened only with Alt-S and not with the Stop button.
« Reply #5 on: May 27, 2013, 07:02:49 pm »
Ok, thank you Juan.
« Reply #6 on: November 04, 2013, 07:11:04 pm »
Juan,
What is your judgement about this by now ?
« Reply #7 on: November 04, 2013, 07:53:16 pm »
Juan,
The turn off issue never happened again.
However if I click Alt+S previously to Alt+X, the music stops but the GUI don´t reappear, I have to click Alt+X again to get the GUI.
To have all working normally I have to click first Alt+X and then Alt+S.
I´m always talking at Unattended.
« Reply #8 on: November 04, 2013, 09:07:09 pm »
Juan, that is normal.
Thank you for the feedback.
