November 23, 2024, 10:06:54 pm *
Author Topic: 09-z9. Not Wallpaper Coverart and other problems  (Read 7525 times)
« on: May 27, 2013, 05:37:32 pm »
Some problems:
- There is not Wallpaper at all when I play with OS Minimized and at Unattended with Show as Wallpaper and Show Back active, the only thing that shows (if I activate it) is the OSD and not always. I wonder if you have it off in your signature only for SQ reasons.
- Alt+S repeat the last notes before it stops totally.
- Alt+S sometimes turn off totally XXHE.
« Reply #1 on: May 27, 2013, 05:53:50 pm »
Careful not to end up in paranoia. Happy
Windows 8, right ? Since when did Windows 8 show any Wallpaper during Unattended ?
It can't.
Repeat last notes ? Isn't that Phase Alignment ?
In Unattended ??
And if you don't agree Juan, than make separate topics of this. Ok ?
« Reply #2 on: May 27, 2013, 06:03:05 pm »
It can't.
Yes, I´m using W8 and sorry, I didn´t know it doesn´t show Wallpaper.
It happened a couple of times and I had not Phase Alignment activated.
« Reply #3 on: May 27, 2013, 06:14:14 pm »
Ok. I thought you used Windows 8 before ...
Anyway it made me realize that this is to be obtained in the Release Notes as a general remark/issue. So I just did that.
« Reply #4 on: May 27, 2013, 07:05:56 pm »
The OSD will always appear, but sometimes it needs much "pressure" from the OS and it can take long.
Look at the OSD Running Time for fun (the digital one). It hardly works.
This is exactly the reason why it will be better to shut off all OSD stuff, including the Wallpaper (I think that is reflected in my sig). Windows 8 has another (super slow) layer there and it can't be avoided.
« Reply #5 on: May 27, 2013, 07:07:48 pm »
Ok, thank you Peter
