November 23, 2024, 08:55:38 pm *
Author Topic: 9z-9, windows 8: "XXEngine3.exe has stopped working"  (Read 20530 times)
« Reply #15 on: May 28, 2013, 06:39:09 pm »
Use a long cable (all can easily extend to over 12 meters - I use that here too).
Otherwise, what about Bluetooth audio devices being made available by the install ? Maybe there it goes wrong (especially when it still occurs that already at the start of XXHighEnd XXEngine3.exe crashes.
Disabling them would be the solution, although I think that should happen in Device Manager.
But what changed that you weren't bothered by this with your previous W8 installs ??
Do you mean that I should disable the "audio" devices that are part of the bluetooth installation ???
« Reply #16 on: May 28, 2013, 06:47:15 pm »
Yes.
You are not using any audio part of it.
But of course the audio devices only, not complete "hubs" or anything. Actually those who appear under the speaker icon in the Taskbar Tray (under Normal OS).
Alain, I am just guessing for solutions. Maybe it does not help at all. And again, what changed since you worked with it ?
(and I anticipate it is not me, which also can be the case - although I can't see how.
« Reply #17 on: May 28, 2013, 07:00:25 pm »
As my net tendency is to stop almost everything on the pc, I have kept asking myself if I was forgetting something. Like you mention, it was working before, so there should not be any error...
In doing a test with 83a, I should determine if there is something missing. Rest assured that I will take notes about what I did to make things work as it was before...
This time I will try to be a little more brilliant and create a restore point.
« Reply #18 on: May 28, 2013, 07:55:59 pm »
Well, what do I know... I did not deactivate the "Alain-PC stereo" (that's the name of my "all purpose" pc) that appeared in Device Manager under Audio after I connected through bluetooth with my music pc...
You were right, I forgot that. Thanks Peter. All seems ok there !
Now I listen to something that relates to this: "Mas que Nada" Happy
« Reply #19 on: May 28, 2013, 07:59:06 pm »
Ok good. That's one problem solved. Happy
« Reply #20 on: June 01, 2013, 05:37:35 am »
This is solved in 0.9z-9b.
The general problem of this topic was about the Decimal Separator when set to "," (comma) implying strange things.
