November 23, 2024, 06:09:38 pm *
Author Topic: 9z-9, windows 8: "XXEngine3.exe has stopped working"  (Read 20515 times)
« on: May 27, 2013, 02:31:21 pm »
I tried the 9z-9 latest version of XXHE with W7: all works fine. I even copied your config, except for "Stop all Services", since I need bluetooth to access my music pc. Same (all is OK).
Windows 8: I can't even get to play anything. No matter what, the "XXEngine3.exe stopped working" pops up each time, before the music starts.
My W8 installation is a fresh one. The administrative permissions were applied by XXHE as expected, the .net framework 3.5 downloaded and installed itself, the activation went fine, etc... I installed Explorer 7 to cut the "Metro UI". All went fine for these.
All I added was the latest drivers for the Sotm PCIex USB 3 card, the Imdisk (ramdisk) latest version.
No matter what adjustements I do, when I start XXHE at first, the message about the XXEngine3.exe appears. And when I am in XXHE and press Play, it does it again.
I tried all combinations in XXHE config, but it does not seem to even need a bad combination to crash: it does it before the XXHE GUI appears, so before playing... I restarted the pc many times, changed the USB cable, connected it through mobo USB ports (USB 2 and USB 3)...
I have to leave now. At my end of day, I will reinstall W8 (because after I encountered this problem, I even tried Windows Update just in case).
It was a fresh install of W8. I will redo all at the end of day, without Explorer 7, Imdisk, et al... Just to simplify the amount of variables...
But it works without any problem in W7 here.
« Reply #1 on: May 27, 2013, 02:36:12 pm »
Alain,
So, what about trying a normal USB2 port ?
I think that will help.
Next, that driver may sit somewhere (look at the services and processes) which will be killed by XXHighEnd when there indeed. Thus, exclude those from being shut off ...
At least I assume it is something like that.
« Reply #2 on: May 27, 2013, 03:39:18 pm »
So ok, I will reinstall W8 (from a backup) and not install anything (no Sotm drivers, no Imdisk (ramdisk), no Windows Update (I did try as a last resort)) just to be on the safe side and report back later for tomorrow. I will try with and without Explorer 7 also. To its simplest expression Happy
I did try a regular USB 2 port from the motherboard...
Thanks.
PS: I am not sure about the attempt from XXHE to shut off the driver from the Sotm, as I have not tried Minimize OS yet, nor unattended...
« Reply #3 on: May 27, 2013, 04:13:43 pm »
Alain, I missed the part of you USB2 trying already. Sorry about that.
I don't think you need to reinstall the OS. Still it must be sound driver related. Notice that starting XXHighEnd runs through those (XXEngine3.exe does that) and since then it already goes wrong ... I think it must be related.
Before reinstalling the OS I'd try uninstalling those SoTM drivers first.
« Reply #4 on: May 27, 2013, 04:31:43 pm »
H Peter,
I will do (only remove the Sotm drivers), yet I will ultimately reinstall W8 (after that verification), since I let Windows Update do its stuff as a final attempt... But as I have an Acronis backup of a fresh and activated W8 installation, in less than 10 minutes, it is up and running. Well... Add maybe half an hour for a few obvious things Happy
« Reply #5 on: May 28, 2013, 03:35:50 am »
I removed the sotm drivers, connected the NOS1 to a USB 2 mobo port, but it does the same as mentionned. I then removed the Imdisk (ramdisk), then finally the Explorer 7... Same again.
I restored a W8 backup. This backup was taken right after I installed W8 and had it activated. So it is "virgin" W8 x64. I installed the strict minimum: XXHE, .net 3.5 framework, NOS1 driver (the one you provided me when I bought the NOS1 and it was for W7 and W8), Explorer 7... XXHE is not even activated for the moment. I only adjusted the buffer (4096), the contiguous memory, the upsampling and the setup required ("Is a NOS1", dac is 24/768), specified the music folder... I did not touch any other parameter (all like it is when we receive it).
Same error...
I then deactivated the upsampling. The music started, played for a few seconds then the error occured again.
There is also an error that mentions that the clock resolution was asked for 5ms and the system returned 1,00003ms (not sure about the amount of zeros...
I tried the 09-z83a and it works fine...
By the way, I did not even changed the regionals adjustments so a decimal separator would be the "." instead of the ","... Just in case it could explain something...
I don't know if I should install all from scratch (not from a backup) just in case... But if 9-z83a works with the actual installation... ?
« Reply #6 on: May 28, 2013, 08:13:33 am »
Well, this is exactly what I am thinking of. Maybe not the decimal separator, but the language (assumed you work in French). Can you switch to English with your OS ? (Pro should be able to do that).
But something is wrong with either that decimal separator or the language itself. At least that's what I get from here : 09-z9 Music stops after 6 seconds. Also "able" to play briefly ...
Maybe don't fuss around too much. I think when I solved the problem from that other topic, yours is solved as well.
« Reply #7 on: May 28, 2013, 11:59:36 am »
You are "spot on" ! It works fine when I change the decimals from "," to "." Happy I normally do this automaticaly, as I sometimes use French to write and English to program (even if I don't do that on my music pc), but I simply forgot this time...
PS: I was not sure about the ability to change the system language with W8 pro... I will check on this.
« Reply #8 on: May 28, 2013, 12:30:40 pm »
Thank you for your efforts and confirmation Alain.
« Reply #9 on: May 28, 2013, 12:37:06 pm »
I talked too fast unhappy
It does not work anymore... I don't know what could have changed this behavior...
The 2 only things I did was to install the Imdisk (ramdisk) and the bluetooth software. Then I rebooted.
I removed the 2 of them, but nothing works anymore...
I will restore again and retry...
« Reply #10 on: May 28, 2013, 12:54:05 pm »
Alain,
You wouldn't be the first one who received problems after installing the Bluetooth software on Windows 8.
It is only that you never had those problems ...
But can you be more specific about what happened ?
« Reply #11 on: May 28, 2013, 01:42:26 pm »
Apart from the decimal thing (".") it seems that the bluetooth software interacts in some way. I can't say more, but as long as I don't install it (this is my conclusion for the moment), XXHE behaves fine with W8 and no visible anomaly... I have yet to try in Minimize OS.
It seems that I will need the use of a software like tightVNC since my equipment is not well organized for a direct connection with a keyboard-mouse combo... But of course it is feasible.
I was wondering if accessing the PC through a USB dongle (wireless) for a keyboard and a mouse would be worse for SQ than accessing the pc from a wired network ? This, provided that I don't use the same USB controller to access the DAC ?
So this is were I am at the present time.
« Reply #12 on: May 28, 2013, 03:14:23 pm »
Now I can do whatever I want, provided that I don't install the bluetooth software. When I do, the "XXEngine3.exe" error occurs every time. And even if I uninstall it, the error persists, as if not all files are removed from Windows. If there is one thing that I forgot to try, it was to disconnect the dongle with the bluetooth software installed (and the same after uninstalling it).
I sure can live without the bluetooth software, but if I have to choose between using network (through either Remote Desktop via network OR wireless keyboard + mouse), which one would do the least damage for SQ ?
« Reply #13 on: May 28, 2013, 04:10:41 pm »
Use a long cable (all can easily extend to over 12 meters - I use that here too).
Otherwise, what about Bluetooth audio devices being made available by the install ? Maybe there it goes wrong (especially when it still occurs that already at the start of XXHighEnd XXEngine3.exe crashes.
Disabling them would be the solution, although I think that should happen in Device Manager.
But what changed that you weren't bothered by this with your previous W8 installs ??
« Reply #14 on: May 28, 2013, 04:39:02 pm »
That is a good question... Nothing that I can recall... I am so used to do the sames things, I can't see if there is either an omission or an addition in my methodology. Since it does not take too much time for me to reinstall, I will redo my tests tonight - with z83a and z9 to compare agin. I wish I had a straight answer for you...
Not sure about a KVM cable... This would mean I have to either plug a monitor or use the TV...
Choices...
Page created in 0.126 seconds with 19 queries.
