« on: May 26, 2013, 11:28:15 pm » |
Is it my imagination or is this sounding very very good!
Am in the middle of "tweaking" the new amp so was not willing to introduce another variable - glad I did though.
P
Actually - after further listening WOW how do you do it Peter? it just gets better.
« Reply #1 on: May 27, 2013, 09:18:34 am » |
Win7 or Win8?
regards, Coen
« Reply #2 on: May 27, 2013, 09:41:14 am » |
Yes, I think it is a good idea that everybody mentions which OS it is about.
Thanks ... Peter
« Reply #3 on: May 27, 2013, 09:51:26 am » |
W7 for the moment as in signature.
Peter - is this a placebo effect should I be hearing SQ improvement in W7?
« Reply #4 on: May 27, 2013, 10:04:36 am » |
No placebo if all is right Paul. All what has been done on behalf of Windows 8 helps WIndows 7 also. Except "half" of the application of Q5, which helps Windows 8 more than Windows 7 (see ToolTip).
Otherwise the Sound Engines have been rewritten largely and that too helps audibly.
For me all is a bit more difficult to judge because I am listening through all improvements at the same time, added to that my super-duper footers for the NOS1.
Notice that my current sig for W7 does not reflect my latest best choices (I just didn't update it), though it is fairly equal to the W8 settings. Only Clock Resolution I ended up for W7 is 0.5 and Q5=2. But since I later changed that for W8 to 1 and 3 respectively and I never went back to W7, that too may be a good setting for W7.
stefanobilliani
« Reply #5 on: May 27, 2013, 10:22:01 am » |
W8 . My impressions are good , quite good . We start with a new era in music through XXHE .
Great job . I may add that everything is working for the exception of Alt-m ; another problem in W8 ( also other versions ) is that the system is unable to engage " stop remaining services " , but I'll open a thread for that .
Regards
Stefano
May 27 -2013 , 0.9z-9
W8 pro 64bit, UEFI sata ahci mode . i7 (8 cores ) 2600k RAM : 16Gig XXHE on OS disk Music on OS disk Playback drive on USB3 to 4Gig Pendrive Mobo USB 3 to Oversampling dac at 2X KS adaptive , ArcPredict , dev buffer 1024 Q1=8 , Q5=3 , res 1msec Minimized OS , stop all services X-tweaks : 45,100,1,1,1, stable , optimal Disk Utilization : Split File Size: 120 ,max the same as SFS Memory Organization : Straight Contiguous
« Reply #6 on: May 28, 2013, 05:00:43 am » |
Here are some first impressions:
1. 9Z9 (Peter's W8 settings except SFS @ 60)sounds better in W7 than W8. W8 sounds a bit more veiled to me.
2. In both W7 and W8, 9Z9 sounds best without the ASSI Rainbow Sugar Card (I didn't make that up!) It definitely puts a bit of a blanket on the sound.
3. 9Z9 in general is just a bit too fat in the mids resulting in less well defined vocals; though W7 sounds much more defined than W8.
4. 8e in W7, with Rainbow Sugar (the AFX-104 filtering card), continues to sound fabulous here.
« Reply #7 on: May 28, 2013, 02:06:49 pm » |
Couple more observations I forgot to mention last night: 1. 9Z9 sounds very, very good. To me, it sounds much improved over 8-3a. 2. Turning on peak extension in 9z9 kills the sound. Guess that problem was solved--would love that tweak applied to 8e  . 3. Phase Alignment turned on sounds best here in 9z9. I used my W7, 8e, PA settings.
« Reply #8 on: May 28, 2013, 10:27:49 pm » |
Very early days here, but I'm really liking what I'm hearing. There seems to be more depth to the sound. I'm attributing this to simply more 'real' resolution, even with much higher SFS and Q settings than I normally have.
More thoughts later, but for now a real step up in SQ I think...
« Reply #9 on: May 29, 2013, 11:26:31 am » |
W7.SQ is certainly clearer than the previous version. However I continue to get better SQ with PA on & XTweaks off.
Another jump towards better SQ. Great job Peter.
« Reply #10 on: June 02, 2013, 08:52:42 pm » |
So I played with Q5 @1 this morning and vocals sounded very similar to what I like best about 8e. The base though, with 9z9, is much better and the sounds of the instruments in space were more defined and palpable. I was A-Bing Dave Brubeck, Take Five, and in 9z9 the first few measures, though soft, never sounded so live before. I briefly listened with Q5 @ 10 and, though it sounded incredibly smooth, it was less dynamic than Q5 @ 1.
A-Bingbetween 9Z9 and 8e it seemed a bit odd that volume levels were the same. I played Brubeck @ 22.5db, in both the volume seemed the same. I should have used the SPL meter but it wasn't readily handy. I thought 8e would have to be played 3db louder because of using peak extension.
« Reply #11 on: June 02, 2013, 09:10:18 pm » |
Hey Brian,
That is W7, right ?
Well, for me with W8 it is a sort of the other way around ... No problems anymore with too loud hence "too dynamic". Only hits on cymbals and other "fast" instruments incur for that now. But that is actually for the better IMO. Of course now *that* starts to emphasize that it needs somewhat more to really get there. But that's a good thing too I think because now we can focus on something ...
« Reply #12 on: June 02, 2013, 09:13:54 pm » |
Yes, W7.
« Reply #13 on: June 03, 2013, 12:13:49 pm » |
After readjusting my listening experiences with a CD-player for one week, I installed 09z-9b on the W7 PC. (Settings see sig)
This XXH release is the best ever. The amazing sound of the cymbals are back.
Great Job Peter.
Michel
« Reply #14 on: June 03, 2013, 03:18:32 pm » |
Great Job Peter.
Agree.  (w7 ultimate64bit)
