April 05, 2025, 04:14:37 am *
Author Topic: SeVeReD's 6-13 PC build  (Read 31467 times)
« on: May 19, 2013, 06:23:17 am »
Starting to think about a new PC build to keep up with XXHE and start playing around again.
Which i7 processor from the link below do I want to go with and build the PC around? (I want to get an i7 still right?) MotherBoard considerations?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100006676&isNodeId=1&Description=Intel+Core+i7&x=-1025&y=-112
Thank you
I'll post a final here when I'm done putting pieces together.
« Last Edit: May 27, 2013, 11:23:38 pm by SeVeReD » Logged
« Reply #1 on: May 19, 2013, 01:50:06 pm »
I've had great results with the Sandy Bridge 3930 with an ASUS P9X79 WS motherboard. I believe Mani and Nick use the same cpu and mb, When others were having frequent stopping issues with XX version 8e, I was and still am largely unaffected, maybe 3x's a month, if that, the program will stop in the middle of a track. The ASUS WS mb has two PS/2 sockets for a mouse and keyboard which sounds cleaner than usb types. Also the mb has a great bios interface for overclocking and other bios tweaks. Just my 2 cents. Don't knowabout the other cpu's in your link or other mb's.
Also, you can't not read through the thread started by Juan about his computer build. Lots of important stuff in there. Good luck!
i
« Reply #2 on: May 19, 2013, 07:58:09 pm »
hmm why is it always the expensive ones in audio... hehe
well it gives me the direction the machine will take.  Thanks for reminding me of the computer build thread too.
dave
« Reply #3 on: May 27, 2013, 07:11:00 am »
Well...
I've spent the last two days reading here (Juan's thread) and looking at all the motherboards out there and this is what I've come up with...
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492
ASUS P9X79 WS LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 SSI CEB Intel Motherboard with USB BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131798
hehe really? Since some of you've put together your computer awhile ago and nothing really better/economical has come out?  Anyway, someone let me know if there is a better combo.  The biggest limitation is trying to find a board with both mouse & keyboard PS/2 ports.
Now, my last computer has lasted about 5 years and I expect this build to last as long for XXHE... I hope.  (My computer is going strong I just need to give to someone to help them rip their collection and I thought I'd move up).
Now this ?
Should I fill up the memory in hopes of the future XXHE and hopefully me getting a NOS? at some point?
How much is too much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231523
« Reply #4 on: May 27, 2013, 08:21:31 am »
Dave, secret topic : http://www.phasure.com/index.php?topic=2084.0;all
Can be shipped together with the NOS1 btw. swoon
Arjan
« Reply #5 on: May 27, 2013, 04:23:52 pm »
Hi Dave,
I use the ASRock X79 Extreme4-M micro ATX mobo. It might be cheaper then the Asus. It works fine for me. Maybe Asus has more features, but for SQ they are not needed.
regards, Arjan
March, 2024 (2.11)
« Reply #6 on: May 27, 2013, 05:43:13 pm »
For now,
Has it ever been determined how much memory is too much for an XXHE computer and/or what might XXHE be able to utilize in the near (5 yrs) future?
I know XXHE likes a pretty powerful computer.  But I also know that Peter/people shut off as much as possible on our xxhe computers (taking HDDs offline, bluray unplugged, fans off.....)
So how much memory is too much before it becomes a detriment to SQ.
« Reply #7 on: May 27, 2013, 05:57:20 pm »
Nothing is too much that I know of. What's useless is another thing;
12GB sure is enough. 16GB is "now you can do everything and all" (also don't forget RAMDisk stuff).
8GB works but is tight.
More than 16GB is a waste.
Less than 8GB is a pain and not good for SQ at all. But it works.
(I forgot to order the sequence. grazy)
HTH !
« Reply #8 on: May 27, 2013, 06:04:05 pm »
Hi Dave,
regards, Arjan
I'll look again through their stuff thanks, good to know it works well for you.
« Reply #9 on: May 27, 2013, 06:16:23 pm »
FYI : That's the one which us used in the XXHighEnd PC as well (the PC I linked to earlier today).
And I'm not so sure it does less than an Asus. The contrary ...
« Reply #10 on: May 27, 2013, 08:20:01 pm »
HTH !
Thanks Peter,
The machine will be doing double duty as a video/internet/gaming computer too, so I have those considerations also.
btw
I do think I have a very clean way of keeping XXHE vs All other computer duties separated.
I have one drive with OS win7 for video/internet/gaming, and another HDD with OS win7 exclusively for XXHE.  I just plug/unplug a sata cable between the two different OS drives (oh ya and turn on/off&plug/unplug various HDDs-not hard) and I'm back into pure XXHE mode.  Since loading 8-a3, I've not left minimized mode when using the HDD for OSwin7/XXHE.
one last also,,,
This machine does NOT have to be quiet.  It is in a closet in the next room to the music room (I've "punched" minimal holes in the extensively insulated walls for the wires)  So, jet fans are welcome, as long as they don't mess up the SQ, say by electrical interactions... How's that dual PS study coming?
« Reply #11 on: May 27, 2013, 09:40:08 pm »
Hey Dave,
Dual PS ? No clue what you are talking about. I must have forgotten something.
Notice that today's PC (built up like Juan's or ours) are perfect HTPC machines. So no worries there.
Lastly, careful about the not being quiet because it implies a longer distance to whatever DAC. That is never good ...
« Reply #12 on: May 27, 2013, 11:22:14 pm »
Hey Dave,
Hi
The FF800 DAC uses 2m from the computer, then a quick analog interconnect jump to the PASS xover, then a long analog ic jump through the wall and to the amps!
Wasn't there talk of using one PS to run the MB and another PS to run peripherals?? something like that?  had to run a shortin jumper on one PS to fool it into thinking it was also connected to a MB haha.
« Reply #13 on: May 28, 2013, 08:15:17 am »
Yes, I saw that passing by. 9 months ago or so. Maybe 8.
« Reply #14 on: June 09, 2013, 03:15:39 am »
On this page the memory they have from
DDR 1600
to
DDR 2400
Which direction should I go considering a XXHE computer?
Thanks
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=G.SKILL+Trident+X+Series+32GB+%284+x+8GB%29+240-Pin&N=-1&isNodeId=1
or maybe I should ask...
what timings should I shoot for?
