November 23, 2024, 06:41:35 am *
Author Topic: 09-6 Settings  (Read 6091 times)
vrao
« on: April 14, 2013, 02:45:30 am »
 looks like everyone has moved to the newer software version. Does anyone have their old settings so I can restart my program? I ended up playing XXhE without turning on the NOS, and XXHE selected a default device, and some how I never saved a working preset  unhappy
 Now I'm getting ticks with FIFO errors  unhappy
vJ
vrao
« Reply #1 on: April 14, 2013, 06:08:48 am »
Ok got it going, after a frustrating afternoon, figured out the wrong USB port on the PC. Who knew what a pint of beer could do for problem solving  Happy
VJ
P.s it would still help to have at least on set of parameters somewhere here on the form for reference!
« Reply #2 on: April 14, 2013, 11:38:03 am »
vrao,
What about everybody's sigs ? All really should be consistent to older versions once the newer options you might see are just skipped.
Regards and cheers !
vrao
« Reply #3 on: April 15, 2013, 03:53:14 am »
I did try that at first, but most have changed that to the newer version. I don't blame them, probably better anyways. Just brings up to the subject of me upgrading, which I should soon .....  Wink
VJ
