April 02, 2025, 10:05:10 am *
Pages: 1 2 3 4 [5] 6 7  All
Author Topic: PCI supply rail noise  (Read 121872 times)
« Reply #60 on: April 25, 2013, 04:13:29 pm »
I´ve received the card, at the end it was the Pro version. What I´d like to know is if the card is correctly installed and detected by the system, I looked at the bios but I can´t see nothing neither in the Device Manager. The light in the card is ON, that´s it.
In general the sound seems to be clearer and the bass tighter with more nuances. However I´d like to be sure that the system has detected the card.
« Reply #61 on: April 25, 2013, 04:13:53 pm »
I think mine won't arrive. dntknw
But Brian, these pops as you described them, where they during playback only ?
« Reply #62 on: April 25, 2013, 04:15:36 pm »
Juan, the card is "nothing". It contains no logic. Only a bunch of capacitors paralelling the PCI voltage rails.
« Reply #63 on: April 25, 2013, 04:24:08 pm »
Ok, I understand. After half an hour or so and as a first impression I confirm that there is an improvement in the sound. More clearer and not bright at all, in my opinion a good acquisition and another step ahead in SQ. I´ll see the evolution after a few days but so far the change is noticeable for the better.
Thank you for this good idea Nick,
« Reply #64 on: April 25, 2013, 04:26:04 pm »
The popping started during playback. I stopped XX and the popping stopped for a few seconds but then came back. Turned off th PC, removed the card, restarted and played incident free for hours.
« Reply #65 on: April 25, 2013, 04:30:18 pm »
Has anyone besides me left the pc on for hours, no music playing and then had no problems?
« Reply #66 on: April 25, 2013, 04:44:24 pm »
The popping you describe sounds like some kind of oscillation. Could be a malfunctioning capacitor or resistor though.
Anyway are the any psu wires in the vicinity of the card?
Regards, Coen
« Reply #67 on: April 25, 2013, 04:58:16 pm »
Cohen, no psu wires but i did move the card to slot #1 which is perpendicular with my memory modules, so close that they (memory and X card) almost touch. Could that cause the oscillation you describe?
« Reply #68 on: April 25, 2013, 05:56:34 pm »
Memory can really get some warmer ...
« Reply #69 on: April 25, 2013, 06:09:21 pm »
I may have another tweak ...
The position of the card on the bus can be important. Imagine current flowing from, say, left to right, then I suppose that the card should be on the farmost left slot. Or put this the other way around : it could have zero effect when put in the rightmost slot. In the middle it would only serve the slots to the right of it.
Now before someone asks "Peter, how to orient the MoBo so we see the left ?" ... don't ask me. And possibly each slot has its own PCB traces which makes my tweak rather moot (but it can still make a difference). Anyway, I'd try both ends of the bus, when possible.
« Reply #70 on: May 01, 2013, 06:10:57 pm »
After around 100 hours with the card installed I can confirm the sound differences. Without the card the sound seems bigger in some way but it looks like if it would have a cottony texture, I mean it looks soft and poorly defined by comparison. By contrast with the card installed the sound is clearer and with much more defined edges.
At the end I think it is worthwhile to have the card, the difference in SQ is noticeable.
« Reply #71 on: May 01, 2013, 06:54:02 pm »
Thanks Juan-your helping to tip the scales in favor of me buying another card.
« Reply #72 on: May 01, 2013, 08:34:29 pm »
I hope you have better luck with a new card
« Reply #73 on: May 09, 2013, 04:48:32 pm »
Hey Peter, haven´t you received the card yet?
« Reply #74 on: May 10, 2013, 03:51:04 am »
Hi Juan,
It did in the morning I left for a small vacation. Haven't had a chance to try it. But I will soon now because to all comes an end, like this vacation.
