November 25, 2024, 04:04:55 pm *
Pages: 1 2 3 [4] 5 6 7  All
Author Topic: PCI supply rail noise  (Read 120751 times)
stefanobilliani
« Reply #45 on: April 21, 2013, 04:47:59 pm »
I also did make new diy power cord . And IT make some difference .By request I can post a picture and details somewhere here .
S
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #46 on: April 21, 2013, 05:17:23 pm »
Bert, are you still on Windows 8 ?
No, no...back to W7 long time ago. I will update my signature... ;-)
« Reply #47 on: April 21, 2013, 05:19:54 pm »
Could you give some more information on your new power cords?
Hi Stanley,
http://www.phasure.com/index.php?topic=2547.msg26357#msg26357
http://www.phasure.com/index.php?topic=2547.msg26364#msg26364
Just read through that topic further down.
« Reply #48 on: April 22, 2013, 04:47:23 pm »
Yikes! Got up this morning, turned on some tunes and suddenly it felt like vocals were being shouted at me. Yuck. Pulled the new card out, and, voila, all was right. Have now put it back in and am hoping the natural timbre of voices returns. For further context, I left the computer on last night, no music playing; night before all was off.
Then again, could be those washing machine blues!
« Reply #49 on: April 22, 2013, 05:02:00 pm »
....a little more context: Till last night the card seemed to make the music soudn better and better, was very impressed. Thought I could speed up burn in by leaving the PC on all night. But awoke to "Yikes!"
« Reply #50 on: April 22, 2013, 05:40:31 pm »
Yea, well, out of control tweaks. I recall I said something like that ?
swoon
What about leaving on your PC today the whole day and try it tonight ? Should be the same then. And now washing machines are excluded.
Btw, with this it can even be so that a brief power down (just 1 second) already cures it. Just as well that in a snap all can be destroyed. Just think about the lot running into a resonance it won't recover from (but will by detaching power).
« Reply #51 on: April 23, 2013, 02:27:22 pm »
Well, tried all of your suggestions Peter and washing machines are not the issue. It feels like it's malfunctioned, voices have a terrible glaze. Will wait to see other's experiences before ordering another one. Peter, thanks for your input.
« Reply #52 on: April 23, 2013, 03:37:53 pm »
Brian hi,
We have the same mother board etc and I am not getting the symptoms you describe, could the problem could be unrelated to the x-sound card ? Does the sound get back to normal if the card is removed  ?
I received my second card in the post today, I fitted it and i think there may be a cumulative improvement. I need to a b sound quality with the second card to check its effect however because a lot of other stuff has been changing with my new amplifier build.
« Reply #53 on: April 23, 2013, 04:13:54 pm »
Hi Brian,
Thinking about my own description earlier in the topic of how this works (should work for the better) it's one big lottery. Nothing will be malfunctioning but bad luck on the "resonance" can easily be your part. The capacitors just add noise to everything and each does it at its own rythm (1000s of times per second).
It is more complex because while their loading adds noise, they also contribute to the supply they drain (draw) upon themselves (contribute in parallel to the normal supply).
If you are unlucky today you may be lucky next week. And the other way around. Capacitors wear.
This, btw, is also why capacitors need to stay way cool, like the under 40C/104F in the NOS1; They last a 100 times longer than what they are rated for (often at 65C/1149F) which is for a reason (work is less hard at lower temperatures). So ... when your voices start to shout with the PC being on longer, it's probably because it's more hot in there than earlier. Just guessing for a reason ...
This would not be my tweak (though I ordered 2 swoon).
« Reply #54 on: April 23, 2013, 06:48:05 pm »
Did you try different PCI or PCI-E slots?
Renards, Coen
Jud
« Reply #55 on: April 23, 2013, 08:42:50 pm »
OK, what would be?  (Please don't say "magic feet."  no )
« Reply #56 on: April 23, 2013, 09:32:47 pm »
You tempt me. By pure coincidence or other magic, I just create those myself only 5 days back. But I won't say anything about it because of course it is a secret.
yes
« Reply #57 on: April 23, 2013, 10:17:12 pm »
Yes, as soon as the card is removed the natural timbre of voices returns. I'll give Cohen's suggestion of changing slots a try tonight. Thanks to all for your input!
« Reply #58 on: April 25, 2013, 01:34:53 pm »
I have now had some time to do A B comparisons on the use of 1 or 2 X-Sound cards fitted on my PCIe bus.
I find that using one card I still hear the positive change in sound quality that I described earlier in the post compared with not having as X-Sound card fitted.
When a second X-Sound card is added, the prominence of high frequencies drops and there is a corresponding loss of presence and detail. The sound is slightly dull relative to the using one card.
« Reply #59 on: April 25, 2013, 04:10:08 pm »
Thanks for the update Nick. Well mine has definitely malfunctioned. Yesterday I put it back in and after an hour I got this terrible low frequency popping--thought I was going to blow a speaker. Took the card out and played problem free for hours. Am tempted to order another cause the sound was so good until the day I left the pc on, no music playing. Thats when vocals turned to shouts and it never recovered. It would be great if others besides Nick, Paul and Bert would post your respective findings. Peter?
Page created in 0.15 seconds with 19 queries.
