November 23, 2024, 04:24:46 am *
Author Topic: New tweak  (Read 6210 times)
Tore
« on: April 10, 2013, 09:54:53 am »
This is a old tweak from Steen Duelund, the man behind www.duelundaudio.com
The SQ is more coherent with this carpet between the speakers.
Tore
« Reply #1 on: April 19, 2013, 12:44:58 pm »
Hi Tore,
Another tweak could be :
I don't know how "square" your room is (it looks like the width could be similar to the length) but when you move all to the 90 degree other wall, your seeling will do magic. So if you can easily try it, you should.
Another thing I personally found is that your floor material somehow emphasizes the good of rock music (but is maybe not the best for other types).
Lastly, if you change that carpet behind the speakers into some art work, you are able to focus on it - which happens without attention. This does something for staring in the blind. Now you almost need to close your eyes first in order not to look sideways (just because there's nothing to see otherwise).
Strange tweaks perhaps, but I thought to respond with "something" at least.
Regards !
Tore
« Reply #2 on: April 19, 2013, 02:21:39 pm »
Hi Peter!
My room is 3X5 meter so i can`t have the speakers on the long wall.
On the floor i have a thick carpet but you can`t see it on the picture.
Tore
