December 21, 2024, 03:44:51 pm *
Author Topic: 0.9z-8-3a Volume does not work ?  (Read 6436 times)
« on: April 09, 2013, 12:25:11 pm »
I have a problem with 0.9z-8-3a. The Alt+U or Alt+D to turn up or down the volume level don´t work, although in the wallpaper appears the volume level as changed
« Reply #1 on: April 09, 2013, 12:39:13 pm »
Juan - Think about other settings you changed. Not that any of them officially implies "volume change can't work", but I think it is possible to "stress" your system so it does not work.
Btw, quite unbelievable when the Wallpaper shows it.
« Reply #2 on: April 09, 2013, 02:06:26 pm »
Peter - Ok, it works, after turning up and down the volume from -42db to -30db I realized that the volume change is very noticeable from one extreme to the other but step by step from -1.5db to the next level it is hardly perceptible. The change seems to take more time than before, it is like if the volume level changes not as quickly but in a smoother way. That could be the reason why it was hard to perceive the change from, let´s say, -30db to -28db. Of course it could be due to that the system is now more stressed. I´m using your same settings (Ultimate, SFS120, etc.).
« Reply #3 on: April 09, 2013, 04:44:32 pm »
Every once in a while I've had the same problem with the volume not changing, but it's always been with a high res file. If I stop and restart the track the problem goes away.
