November 23, 2024, 04:06:59 am *
Author Topic: Power Cords  (Read 31098 times)
« Reply #15 on: April 10, 2013, 12:18:40 pm »
I don't know. I useD them. And only on the way OUT from a DAC.
« Reply #16 on: April 10, 2013, 01:39:38 pm »
My last system was all Audio Note and the DAC pre amp and power amps were originally powered with standard flex wire. I replaced with home made power cables (neutral / live twisted and earth run separately). I was surprised by the improvement. OK litz may be better who knows.
However, now I have balanced power supply transformer, a dedicated power spur and separate hi fi earth (spike in garden) - installing these made a really big improvement to my current system.
Since I installed the above I have tried standard mains flex and the "twisted" cables with the NOS1 and I could not hear any difference at all. I am tempted to try home brewed litz with the amplifier and NOS just out of interest.
But .... I would be installing say 30cm of litz mains cable which would then be connected to say 25m of power cable in the wall back to the Dis panel mmmm? Still anything is worth a try.
P
« Reply #17 on: April 10, 2013, 01:40:16 pm »
These pangea cable have good reviews in Audiogon. Enter Pangea in the Keywords (http://forum.audiogon.com/cgi-bin/srch_fr.pl?&1&procsrch&3&4&):
http://www.audioadvisor.com/prodinfo.asp?number=PGAC9SE
« Reply #18 on: April 10, 2013, 02:25:06 pm »
There isn't any information but the technique used is similar to the cable shown through the link you've provided. Both that and the Litze made the difference here in my system.
Additionally I have to inform that the way the wires are twisted that they have almost NO outside radiation pattern themselves negatively influencing interconnects or other "sensitive" spots. Its all cancelled out...
« Reply #19 on: April 10, 2013, 06:19:49 pm »
That's why I used double coax.
With a solid core they are inflexible but don't give any hum to their environment. Plus and minus have their own core, the shields are connected on one side to the ground. Big outdoors connectors with rubber surround were needed for this. This way they are releatively easy to build. Just some tape a several places to keep them together.
« Reply #20 on: April 10, 2013, 06:45:35 pm »
Hey GerardA, why you don´t put some pictures of your cables? Would be nice to know something more on the way you guys build your cables. yes
« Reply #21 on: April 10, 2013, 09:04:57 pm »
Haha.
then I'll first have to clean them and get the spiderrags off.
But they look simple, just a big round black plug with two white coax (sattelite antenna) wires and a yellow/green earthwire coming out of that.
« Reply #22 on: April 10, 2013, 09:13:14 pm »
Haha.
Might be a good opportunity to make a general cleaning in the music room, sure someone will appreciate it, lol
