November 23, 2024, 01:30:33 pm *
Author Topic: Can not minimize OS  (Read 6404 times)
MusicFriend
« on: March 19, 2013, 10:57:45 pm »
I'm new and step by step would like to set up my xxHighEnd for the best SQ. Somehow I can not minimize OS.
The version is 0.9z-8-3a, but I'm sure the problem is coused by me...
I can create restore point, but the message just before minOS is: We are sorry but your Reboot into Mininized OS can not continue. You may want to contact Phasure about this.
Please find attached a log file and a screen shot. Please advise.
Kind Regards,
Laszlo
* XX-20130319-210920.log (4.51 KB - downloaded 465 times.)
intel 5-@ 3.1GHz, *8GB*, Windows 7 Professional 64bit on SSD, XX on OS disk, music on SATAII 1.5T spinning disks, Engine#4 Adaptive Mode / Q1/2/3/4/5 = *14*/0/0/0/0 / Q1Factor = *1* (Dev.Buffer = 2048) 24 bits DAC / ClockRes = 15ms / Straight Contiguous / SFS = *120* / *120* / Phase not Invert / *Peak Extension On* / *Phase Alignment Off* / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / Playback Drive = SATA II / UnAttended (Just Start) / *ALL* Services Off  / WallPaper On / OSD On / No Running Time / Minimize OS / XTweaks : *Ultimate* / Time Performance Index : *Optimal*  /HiFace EVO USB-SPDIF> Advance Acoustic MPP505 DAC> Vincent SP331 pwamp> Dynaudio Contour S1.4 speakers
« Reply #1 on: March 20, 2013, 08:22:59 am »
Hi there Laszlo,
It seems that you are not Activated. So, after upgrading to 0.9z-8-3a you may have forgotten to Activate ? And otherwise changes happened to your system so your Code is not valid anymore. This is not your fault of course and only a little inconvenient. Solution in this case : get yourself a new Code through PayPal, and I will return the money as soon as I see it.
MusicFriend
« Reply #2 on: March 20, 2013, 10:37:39 am »
Thank you the quick response. Well, so much to learn, to test... I will upgrade my code according to your suggestion and come back with the result (hopefully with positive).
Kind Regards,
Laszlo
MusicFriend
« Reply #3 on: March 26, 2013, 09:10:53 pm »
Good news! After going through a new activation process I can switch to minOS and some earlier not working functions can be used.
Thank you for the support,
Kind Regards,
Laszlo
