November 22, 2024, 11:18:26 pm *
Author Topic: Monitor shuts down  (Read 19409 times)
« Reply #15 on: March 21, 2013, 04:05:59 pm »
Glad it is solved Arvind. Thank you for the feedback.
CaOd
« Reply #16 on: March 29, 2013, 12:54:17 pm »
Problem solved.
Tried almost everything (reinstalling all drivers for bootcamp, graphics etc), did not change anything. Underclocking / overclocking also no changes.
My problem stem from a limited power supply to the Laptop (I finally should go for a real PC...). Contrary to some advice, I have then simply tried the energy saving mode and twiggled a little bit within to minimize power consumption and -yep!- it works now perfectly with the ultimate tweaks.
Best Carsten
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #17 on: March 29, 2013, 01:17:33 pm »
Ha ! Well done.
Notice that a "limited power supply" often is a deteriorated one (worn).
Page created in 0.232 seconds with 19 queries.
