November 23, 2024, 12:12:11 am *
Author Topic: 0.9z-8.3a: Black screen  (Read 10310 times)
CaOd
« on: March 15, 2013, 10:45:21 pm »
Hi there,
after installing 0.9z-8-3a and activating properly, I clicked on XTweaks Ultimate and clicked on Minimizing OS. After Rebooting, Windows started up normally, but after briefly showing my desktop, the screen turned all black, not letting me allow doing anything. My system is now screwed up, even a hard reset just replicates the procedure. Any help before throwing the computer out of the window?
Thanks Carsten unhappy
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #1 on: March 15, 2013, 10:48:53 pm »
Uhm ... Carsten, if this Windows 7 or Windows 8 ?
CaOd
« Reply #2 on: March 15, 2013, 10:55:27 pm »
Windows 7 Service Pack1
« Reply #3 on: March 15, 2013, 11:06:31 pm »
On your MacBook Pro, right ? (looking at your sig)
Hmm ...
Okay, I guess it really is too late here to provide any real service. But I should be able to help you tomorrow through email. Is that bad ?
How many hours from now will you be up (or ready for it) again ? (say me 9 from now).
Sorry for your troubles ...
CaOd
« Reply #4 on: March 15, 2013, 11:16:33 pm »
Hi Peter, thanks for the offer to help. I am on hour behind you and I have to do the grocery shopping for the family in the morning, so at around 10am your time I will be available to work on it. Any help is appreciated!!
Yes, it is the Macbook Pro in a dual boot environment, I can still access the MAC system and deactivate the Windows boot sectors, but then I have to do a fresh install of the Win system and I try to avoid that. I cannot access a BIOS, since that is an EFi system. Might be possible to get some Unix hacks to change settings.
So far I never had real problems and the system was running stable with XXHE in any mode, minimized and XTweaks applied according to your signature settings.
Sleep well
Carsten
CaOd
« Reply #5 on: March 16, 2013, 12:03:36 am »
So, in my desperate state of mind (and after listening to somem music with Amarra - puhhhhhh...) I rebooted to Windows and simply hit some keys on the keyboard... And the desktop screen came back, very shallow, but back to be able to manoeuver the mouse and click to whatever I wanted. XX is running properly and we can work from here to see if we can get rid of the black screen somehow, I can revert the minimized OS mode and everything, just tell me what is the best approach.
« Reply #6 on: March 16, 2013, 09:57:55 am »
How difficult is it to get the screen back to visible levels ? I mean, could it be a standard procedure after a boot (but then with somewhat more light in it Happy) ?
CaOd
« Reply #7 on: March 16, 2013, 10:39:57 am »
I would prefer this not being the standard procedure (and I don´t remember the keys any longer...), my wife would be lost in operating it and I still like her to be able to run the show when I am abroad (although I have bought a CD transport lately to ease up for her...)
So, if you have any idea how to get back to normal I would appreciate. Thanks Carsten
CaOd
« Reply #8 on: March 16, 2013, 12:20:55 pm »
I guess my problem has to do with my operating system software and is totally (or more or less) unrelated to XXHighend, it looks like it just by coincedence occured yesterday with the upgrade to 8.3a.
You were right, it has to do with the energy options.
I will try to solve it one of these days, so far I can live with the workaround.
Thanks Carsten
 Wink
« Reply #9 on: March 16, 2013, 12:37:03 pm »
Ok Carsten. Thank you for the feedback, and I hope it is going to work out.
Page created in 0.266 seconds with 19 queries.
