« Reply #45 on: March 20, 2013, 01:02:58 pm » |
Still I would say that when you set all the same in 8-3a as in 8e (and Off for that which doesn't exist in 8e) it should sound the same. If not it is unintentional.
Last night I set the 8-3a x-tweak settings, as well as all other settings, to be identical to my 8-d settings below. 8-3a had a better low end feel but vocals remain less transparent and natural sounding. Here, 8-d (or e) continues to sound so "right" that at times it's as though the music is happening in slow motion-- remember the feeling when Bill Frisel was played on 8e? That's the feeling I mean. Perhaps I've become addicted to a very particular sound? Roll another one, just like the other one.......
phantomax
« Reply #46 on: March 20, 2013, 06:19:46 pm » |
Brian, Have you tried with reverse IPhase setting? I tell you because without PA it seems to play a role again, at least in my case. Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
« Reply #47 on: March 21, 2013, 12:13:07 pm » |
Thanks Maxi, I reversed the IPhase setting and had a huge improvement in the sound--much smoother in the high frequencies. I was finally able to listen to 8-3a for more than five minutes. This seems weird to me because before PA days I never reversed polarity with the IPhase button. Will need more listening before having an opinion on whether it's better than 8-d.
phantomax
« Reply #48 on: March 21, 2013, 02:40:12 pm » |
Glad to hear it. Before the PA days I used to try reverse IPhase when I felt that the sound was not as good as it was expected. With certain recordings there were no noticeable differences but with some others the difference was nigth and day. I think that PA reduced the effect in some way and made me stop using it. At the end all this stuff is phase related.
Maxi
« Reply #49 on: March 21, 2013, 07:50:37 pm » |
Maxi
Yep, couldn't agree more.
0.9z-8-3a WAV/CUE files on HDDs via MB FW400>; Win7 pro ttp://www.phasure.com/index.php?topic=352.msg4021#msg4021); [XXHighEnd player Qs 7, 0, 0, 0, 0; eng 4; adaptive; scheme#3; player priority low; thread priority realtime; clock res 5ms: SFS 420 dac is 24/192 w/32bits; Play Unattended; Stop Services ticked; Wallpaper & Show Back ticked - Mirror Image unticked; Start Engine unticked;garbage collect ticked; copy files to XX-drive; *quad arc prediction upsampling*: straight contiguous:>PCI FW800 card>Fireface 800 DAC [latency 2048 samples for 176.4]; usb/ethernet/mb audio shut off @ MB
xp9433
« Reply #50 on: March 22, 2013, 06:29:46 am » |
Boleary What this suggests to me is that there is a high chance that your favourite "test" recordings may be in that category because they all have the same absolute phase? Perhaps, it should encourage you to experiment with recordings you don't like quite so much on the reverse XXHE phase setting, and see if you now like the reproduction better? Frank
« Reply #51 on: March 22, 2013, 08:36:26 am » |
This is not about recordings and reversed Absolute Phase; It is just like the old days (ask Dave (SeVeReD)) ... At a certain level of - call it preciseness, things tend to flip.
By now I can explain it by telling that nothing in the world guarantees that a first highest "pulse" is the positive one when positive was meant. Also it will be different for frequency ranges. All we can tell is that when positive is meant, the average of the voltage will be (more) positive. In the far end you may be able to hear that. But the attacks are more important I think, and these (which pulse is the highest, positive or negative for a frequency) may change per setting.
This was far to brief, but maybe you get the idea.
« Reply #52 on: March 28, 2013, 12:52:42 pm » |
Though use of the IPhase button helped dramatically to smooth the high frequencies here, 8-3a just sounds more digital on my system than 8-d. If I turn on PA in 8-3a and change settings to my 8-d settings, the sound is good but not as wide open and natural sounding as 8-d. The natural sound of 8-d or e is particularly noticeable with female voices. Another advantage of 8-d here is that I don't have to turn iPhase on or off depending on the track, it all just sounds good when PA is engaged.
Just my impressions on my system and I am certainly not complaining cause the sound here in my man-cave is, to these ears, nothing short of stunning!
« Reply #53 on: March 30, 2013, 03:16:20 pm » |
Hi Guys,
After extensive experimenting with 0.9z-8-3a, in my set up the best SQ is with PA on, which means no XTweaks. Far more musical, soft & with the best soundstage. The speakers just seem to become invisible.
Stanray
« Reply #54 on: March 30, 2013, 08:01:24 pm » |
I tend to prefer 3a
Stanley
« Reply #55 on: March 30, 2013, 08:06:22 pm » |
Hey Stanley - Do you have pistons under your speakers ? And what's that in the middle of the floor ? Doctor-gear ?
But this picture really makes me smile !
« Reply #56 on: March 30, 2013, 09:35:10 pm » |
After extensive experimenting with 0.9z-8-3a, in my set up the best SQ is with PA on, which means no XTweaks. Far more musical, soft & with the best soundstage. The speakers just seem to become invisible. Arvind, Maybe I don't know myself now, but how is XTweaks related to Phase Alignment ? I don't think it is ... Regards, Peter
« Reply #57 on: March 30, 2013, 09:40:03 pm » |
What about this setting (W7 / NOS1) :
All what's in my sig, except for Q1=30 and xQ1=10 and next the most important :
Core Appointment Scheme = Nothing plus Clock Resolution = 0.5. This latter combination might do tricks.
Try this on music of which your think it sounds the most (nice and undistorted !) fresh and dynamic but with the freshness in high resolution "more square" (could be synths).
Now let me know what you perceive for changes ...
Stanray
« Reply #58 on: March 30, 2013, 09:44:47 pm » |
Do you have pistons under your speakers ? Haha, no, just a door stop from the Lidl. And what's that in the middle of the floor ? Doctor-gear ?
Yes, my reading glasses
« Reply #59 on: March 31, 2013, 10:08:47 am » |
After extensive experimenting with 0.9z-8-3a, in my set up the best SQ is with PA on, which means no XTweaks. Far more musical, soft & with the best soundstage. The speakers just seem to become invisible. Arvind, Maybe I don't know myself now, but how is XTweaks related to Phase Alignment ? I don't think it is ... Regards, Peter Hi Peter, I don't know if PA & XTweaks are anyway related. The release notes mentions switch off PA. So conversely when I activated PA, I switched of XTweaks. I just assumed this to be the correct thing to do. Are you implying that both features can be simultaneously activated? Let me try your suggested settings & hear if it is as good as PA on. Best regards, Arvind
