November 23, 2024, 09:35:15 am *
Author Topic: 09-z83 Short Names Problem  (Read 20961 times)
« Reply #15 on: April 16, 2013, 09:11:39 am »
Peter - it was a normal SATA disc (two partitions one for the o/s and one for the music) I only have one disc connected at any one time.
I loaded the o/s about 4 times (for various reasons!!) over a period of 2 months the last time I loaded the o/s the problem disappeared. As far as I know I did nothing different on the last o/s load so I have no idea what happened.
Let me know if you want me to try USB I have 64g USB3 stick I could play with - but let me know what you want me to do. I am not using a playback drive.
P
« Reply #16 on: April 16, 2013, 09:21:16 am »
Thank you Paul.
« Reply #17 on: April 16, 2013, 10:34:04 am »
Hi Peter  -  I note that you use a  Playback Drive = USB3 2TB as I said above I do not use a playback drive at present. A couple of questions:
1.  I originally stopped using the playback drive to get round the short names problem (IIRC XX only uses short names for writing to the playback drive). Does the short names error msg come up even if the playback drive is not being used (I thought it did but not sure now)
2.  When I was using playback drive I did not do any meaningful comparison of SQ versus not using it. Do you find it beneficial? I suppose you must or you would not use it but still it would be interesting to know the benefits.
« Reply #18 on: April 16, 2013, 01:19:07 pm »
Hi Paul,
The Short Names are used once a .wav has to be stored elsewhere "on the run" opposed to leaving it where it sits. So, this happens with Copy to XX Drive and with utilizing the Playback Drive. Notice though that the conversion takes place in its "source environment" (hence it is  unrelated to where it goes to like e.g. the Playback Drive).
Re 2. : Maybe this is not a question I should answer. Numerous posts about it exist from off when 0.9z-7 was introduced (August 2012). My vote doesn't count. The vote of all does. yes
« Reply #19 on: April 16, 2013, 06:43:27 pm »
In my case the disk is exFAT formatted. Program code does not fail on it, but with particular Dos commands I can see that the Short Name commands error out.
So, exFAT does not support the Short Dos 8.3 Names ...
Paul, this probably explains why you suddenly got it working; before you had the disk exFAT formatted, and now you applied normal NTFS ...
(let's not bet for whisky this time)
« Reply #20 on: April 16, 2013, 08:33:36 pm »
Mmmm........... each time when reinstalling an o/s I format the target directory from the installation disc. To be honest it just formats and I never checked the file system (I do not remember there being an option to chose it) anyway whatever the default is what my discs will have been formatted to. But without ever looking for it obviously I cannot be sure. I will look out for it in future though.
