November 23, 2024, 02:30:15 am *
Author Topic: Unattended not possible  (Read 7155 times)
Arjan
« on: March 01, 2013, 12:18:57 am »
Hi all,
I have my new audio PC up and running, based on a 3930K processor. And the SQ is super!!!
I have one issue, when trying unattended it never starts playing, the famous message that should disappear will never disappear...... Any suggestions?
kind regards, Arjan
March, 2024 (2.11)
« Reply #1 on: March 01, 2013, 12:53:40 am »
Did you activate and minimise the OS?
« Reply #2 on: March 01, 2013, 08:00:59 am »
Arjan, did you install any Anti Virus software ? if yes, that's it.
Otherwise switch on Logging, wait two minutes with that "Wait ..." message on the screen, click cancel on it and grab the XX log file. There should be a line in there with "error" in it, and between braces () the violating process.
Hope this helps,
Arjan
« Reply #3 on: March 01, 2013, 11:21:31 pm »
Solved! Uninstalled Windows Essentials Security and Unattended is running. Now we are listening to the best SQ ever heard on our system!
regards, Arjan
March, 2024 (2.11)
