November 24, 2024, 12:05:19 am *
Pages: 1 2 [3]  All
Author Topic: Failed to set sample rate  (Read 32454 times)
« Reply #30 on: March 03, 2013, 06:14:58 pm »
Paul,
It is just that you are super confusing ...
You said you switched OFF the facility. That the command you used swicthed it On is something else (and trust me, I check words, not commands per se).
Next, why ever shut it On when it should be clear it's already On ?
Next, why confuse the whole thing not working because of whatever characters in there with any necessity to switch it On (or Off according to your earlier "words").
Lastly, I think you told that removing those characters helped. So ? Done.
Or ?
I guess you missed the fact that the conversion (which is a sheer OS thing) can fail.
How this compares to no problems on W8 I don't know. But maybe you did not say that. So to be clear, these Cantatas never will have worded - not in an earlier XXHighEnd version as well. But if that is is different, let me know (I am not aware of changes).
« Reply #31 on: March 03, 2013, 07:43:31 pm »
Apologies if I am super confusing - I put the actual command in that I used to be clear.
And no Peter I did not miss the fact that the o/s conversion can fail. And I have not missed the fact that it appears to fail with the commas dashes in the file name but not when they are removed. So maybe the bit where it strips those out is not working who knows (and I am sure I don't).
And to be absolutely clear there are no problems at all with W8 (on a completely separate disc) which I have said before.
And for sure I have listened to XX in W7 with previous versions of XX and not had these problems before.
So perhaps I did not have the OS problem before even though it was loaded from the same disc in exactly the same way.
And on top of all of that it has been a really bad day because Arsenal lost to Spurs.
« Reply #32 on: March 03, 2013, 08:12:27 pm »
Paul, don't feel bad.
As you can tell by now I am not so sure at all. I won't ask you to point out that earlier version where it worked, but until you don't I remain right. I hope that is okay with you !
Do notice :
You'd need to play the exact same (which means 100%) with any older version of XXHighEnd and this includes the file type, the "intermediate" drives used and all. So for example, with a .FLAC this won't happen and I think that without any "intermediate" drive (like the Playback Drive or Copy to XX Drive - that kind of stuff) it won't happen either. What won't happen ? the necessity to make those Short Names of it. You can see it happening in the XX Logfile; search in there for
Short Name initiated-1 :
and you will get the grasp.
Enjoy your Sunday evening now !
PS: Just cut out the whole football and all your days will be better. yes
« Reply #33 on: March 03, 2013, 09:52:25 pm »
I don't feel bad - not at all - (I assume you mean the football) actually I much prefer rugby - football is a game played by girlies ha ha.
But one thing you say is interesting about FLAC files. I had most of my files as FLAC until recently - but as they take time to convert in the playback process I converted them to WAV and I did that recently. So maybe that explains why I am getting problems now. But what I do not understand is why others are not getting the same problem. Or maybe they are - come on others let us know if you get the same problem.
Nick was here yesterday and he has "stopping" problems in W7 but he is focused on other things so not reported it.
Maybe the last frontier is the barrier that Microsoft presents between Phasure and a repeatable secure great musical experience??????
« Reply #34 on: March 03, 2013, 10:10:14 pm »
Hi Paul, did you get my PM ?
« Reply #35 on: March 04, 2013, 10:22:09 pm »
Peter - I have removed intermediate/playback disk references (i.e. no longer used) and there are no more problems. SQ is still as good as I could imagine so there are no drawbacks really.
The only problem now is that having pressed play I now have to run back to my chair to get there out of breath as the music starts.
I still get occasional stops with the "Data did not arrive in time message..." but at least I know that I am not the only one!!!
« Reply #36 on: March 05, 2013, 08:13:26 am »
We have a timer for that (counts down) at the bottom. That mini slider. I think max is 60 seconds, which would just allow you to grab a beer from the fridge underway.
Pages: 1 2 [3]  All
Page created in 0.108 seconds with 19 queries.
