November 23, 2024, 09:04:50 pm *
Pages: [1] 2 3  All
Author Topic: Failed to set sample rate  (Read 32425 times)
« on: February 26, 2013, 11:00:26 pm »
With 9z82 on W7 in unattended I keep getting "Failed to set sample rate" error messages using Windows 7 and the music stops. Mostly this seems to happen at the end of a track. Sometimes (but not always) this is followed by a windows message that Engine 3 has stopped which actually means that Engine4 has exited (ie when the XX GUI reappears the blue button is off).
The following does NOT make any difference to the problem:
Low latency (SFS=1 Q1=7) versus high latency (SFS=200, Q1=20 etc).
PA selected or not
This is a fresh and minimal Windows 7 install.
Basically I cannot realistically use Unattended any more and I have run out of ideas as to what to do next to find out what the problem is.
I used to get this problem before in W7 with previous versions of XX but never as bad as it is now.
With 9z81a on W8 on a separate disc there are no problems at all.
I have just re-installed 9z75 on W7 and that also has problems it stops after a few tracks with no error message.
« Reply #1 on: February 27, 2013, 08:10:58 am »
Paul,
With which NOS1 driver is this ?
« Reply #2 on: February 27, 2013, 09:03:58 pm »
Peter - 1.0.3 which is the one you sent me.
No problems under W8 lots of problems under W7.
« Reply #3 on: February 28, 2013, 08:58:51 am »
Ok Paul. Can you please check whether 1.02 on W7 makes a difference for you ?
To keep in mind from another topic : I just mystically have these same problems under W8 (with 1.03 obviously).
« Reply #4 on: February 28, 2013, 09:28:35 am »
Peter - can you please email me 1.02
« Last Edit: February 28, 2013, 09:53:16 am by PeterSt » Logged
« Reply #5 on: February 28, 2013, 09:55:20 am »
Done.
« Reply #6 on: February 28, 2013, 08:14:14 pm »
OK Peter so I have installed 1.02 and it makes no difference. Still I get the error message.
« Reply #7 on: February 28, 2013, 08:20:08 pm »
Good! At least for me, not for you... I do not have the problems you describe.
I have 1.03 installed as well.
« Reply #8 on: March 01, 2013, 08:19:59 am »
Ha ha - I found a work around that Peter may find interesting.
I could just tell you but I thought I would provide the background by way of artistic licence as it took me so b.......y long (and two fresh o/s installs) to work this one out.
Playing Jazz or Blues albums the "Failed to set error rate" message occurs maybe once per album.
But playing say Bach Cantatas is virtually impossible. The "Failed ....." message occurs before the music even starts. Or maybe with luck just one track plays. And it is the same story with other classical music albums they are virtually impossible to play without the "Failed to ...." error message.
All this is in unattended playback attended is no problem. Also this happens for me only in W7 not in W8. And the NOS driver version makes no difference.
So why is the problem so much worse with classical music?  first thought - something to with the music content - unlikely as the cantatas are simple content.
So after an evening at a friends house listening to music (and a few beers) I got home still with the question on my mind what the heck is different about classical albums?
Then I had a really a stupid idea but anything worth a try. So I copied all 22 cantata tracks into a temporary directory and renamed each track "01, 02 etc" I tried to play them but lots of new error messages and playback would not even start. AH HA so track title is important. So then I changed the track titles to "Track 01, Track 02 .... Track n" where n=22 in the case of the cantatas ha ha. Well I was also thinking it could be something to with the number of tracks.
Eureka playback perfect in unattended - no error messages at all. And that seems to be it - classical albums tend to have long track names and that is what seems to cause the "Failed to set...." error to occur.
So the answer is simple all I have to do is go through all my albums (2Tb worth) and reduce the length of the track titles.
Ha ha.
« Reply #9 on: March 01, 2013, 08:23:59 am »
Paul, I also have 2 disks of 2TB, but I could squeeze it into one small one when I convert them to MP3. Is it all right to send that to you so you can rename my tracks as well ? Thanks man !
« Reply #10 on: March 01, 2013, 08:27:52 am »
And oh, when you send back the disk, stuff in ALL the booze you have laying around. It clearly is NO(t) good for you. I can let UPS collect it.
« Reply #11 on: March 01, 2013, 08:29:04 am »
Shouldn't Cantata be played backwards ? or am I now confused with something else. Hmm.
« Reply #12 on: March 01, 2013, 12:32:46 pm »
Ha ha Peter - but why would the length of file names be implicated in this problem? or maybe it is something else I have done?
Or maybe I am dreaming?
« Reply #13 on: March 01, 2013, 12:36:26 pm »
It has to do with DOS filenames longer than 8 I guess ?
« Reply #14 on: March 01, 2013, 12:47:00 pm »
Paul, now seriously, I can't imagine a thing here. But please try this :
Create the same file names as you did (or copy the ones you already have) into a structure which matches the location where it did not work. Something like :
\xyz\MyClassicalAlbumNotworking\Original.wav
\xyz\MyClassicalAlbumWhichWorks\Track01.wav
Then reboot (!) and try again.
But be sure the issue is easily mimiced so it won't be any other coincidence that it now works. So maybe first try the reboot and play the original files and see whether it is again difficult to play them (further like you were used to). If so, then reboot and try your trick.
Curious for the result !
Pages: [1] 2 3  All
