November 23, 2024, 03:29:25 pm *
Pages: 1 [2] 3  All
Author Topic: WARNING : Degraded SQ from off 0.9n u/i 9.0p  (Read 50104 times)
« Reply #15 on: November 04, 2007, 10:44:50 pm »
Quote from: Gerner
If you have ""Appoint processor core" checked, then shut down XXHE and then start Foobar without rebooting, wouldn't this be a problem?  It takes a reboot to clear "Appoint processor core".  This is a long shot guess, probably not related to what you guys are experiencing.
Nope...I think.
I don't have a core appointed to XX. And if I do it....it doesn't sound any different to me...!  dntknw
I had an hour with 9D today. No clicks here. 9m-1 far less. 9p quite some. Foobar stopped clicking after a reboot.
Sorry things run a little fast to make fast conclusions, I think.
Enjoy and cheers
gerner
Hi Gerner,
Not to talk problems out of the way ... I seriously think your 4 core (!) system cannot be judged anyway ... that is including the, say, fact that you don't hear a difference between do / do not tick the Appoint Procssor Core checkbox. You will be having enough headroom to not let it make any difference. On the other hand :
If *you* tick this checkbox, you will be appointing all the processes to one core (the 1st) and the 3rd and 4th would be doing nothing. For your system this would theoretically be worse ...
So a 4 core system is to be tuned differently, and which would be more difficult (I should evenly divide tasks between 3 cores, except for Engine#3 to be run at the 4th on its own).
So, in your case IMO it would be better to not tick the checkbox ...
NOTE : ... which would IMO not be the explanation of *you* having problems now. So I say it again : something is going on ... but not on my system.
Mind you, during playback I let XXHighEnd search / arrange for albums, taking the full 100% of the 1st core for 90 seconds or so. Although it may influence sound because of the second core taking a few % of it (due to drivers which can't be appointed), I do not hear it, let alone crackling appears.
... which STILL does not mean nothing is the matter ... dntknw
« Reply #16 on: November 04, 2007, 11:36:25 pm »
Just for background info :
For those who recognize that their soundcards can respond to a 48 sample buffer, do you realize that this means a synchronized and consistent (meaning : throughout hours) refill of that buffer once per 1 milli second  (1/1000 second) ?
And that this factually means a latency of 3-12 times better than the better digital workstations ?
I only want to say : don't mess with your systems, or increase the latency (if you can), or crackles (skipping of samples) will be the result.
XX is quite stressing your system already for response times. Not for cpu useage (look at my graph a few posts back), but if another process gets to the cpu, even the small number of cycles XX needs won't get there (in time !!).
Okay, you knew that ...
Gerner
« Reply #17 on: November 05, 2007, 06:19:06 am »
Hi Gerner,
... which STILL does not mean nothing is the matter ... :dntknw
Peter it is interesting. Here is some more info.
Say I have a window in my taskmanager showing 4 cores. OK. But they really show the pattern you have on your dual core. It is the same case. One active the other 0.
Further, it seems to make a difference when e.g. you have several XX versions open on your desktop at the same time, including Foobar.
(I do that to have fun comparing all those versions. I normally just throw the same 2 or 3 tracks in to their playlist and swap players.)
I do that a lot, however I do of course not play on more than one player version at a time.  wacko
But doing this swapping between players, even the other players are passified (but not shut down), it increases the clicks frequency.
Now if I leave Foobar alone on my desktop. No clicks.
If I leave only 9m-1. very few clicks.
If I leave 9D the only open player, no clicks.
Does that tell you anything?
PS! I never touch the FF scroller. And I never leave 48 samples, except for Foobar that likes 96.
Gerner
Troubleless playback.
« Reply #18 on: November 05, 2007, 09:30:28 am »
Hi Gerard,
Indeed, before it showed 99 I guess ... ? (which it should !!).
A few remarks :
dwm.exe : your glass look in Vista. Better turn that off (into classic I think).
Explorer.exe : no idea why that is using cpu in your case.
General : 12 % useage is way too much (10 % follows from the list). If you sort the cpu column, at the top the cpu users will appear.
« Reply #19 on: November 05, 2007, 09:40:30 am »
Hi Gerard,
A few remarks :
CPU normally 5, 6, 7.
Normally in my case 95, 96, 97, 98.      But when it happend 87, 88, 90
I Changed bureaublad in clasical weergave.
I did sort the column... what do you like to know?
« Reply #20 on: November 05, 2007, 10:16:29 am »
What is eating your cpu when you have the problems ...
I'm afraid though it's not so easy to find out; I expect it to be a one-time spike (like you showed before) but which possibly keeps on having the DAC de-synchronized until a stop-start is issued.
Let's not forget : no matter I don't have the problem myself, it should be the program that incurs for it now.
The best test might be : unchecking Processor Core Appointment, quit XX, reboot, and let it run so long that you're sure it won't happen anymore (or of course notice it still happens).
Be careful not to use other types of music data than before (WAV/FLAC/MP3).
« Reply #21 on: November 05, 2007, 10:21:50 am »
I will do that...
just playing .Wav right now.....
Right now playing with processetab in front of me and watching if something strange come up when crackling apears...
« Reply #22 on: November 06, 2007, 09:32:48 am »
Gerard,
Didn't you fall alseep by now ?
Must it be the conclusion, almost 24 hours later, you don't have problems when Processor Core Appointment is shut off ?
« Reply #23 on: November 06, 2007, 10:22:32 am »
Gerard,
Hahaha....
No i did not fall asleep.... Did not had the lust yesterday anymore.... I will try that today....And I will find out what is causing the pike... We where planning to  buy a videocamera in a few weeks and when i have that i will put him for my screen and let Processentab open... I will be to late to see,  but i can rewind back....  Grin
Let you know tonight!! (processor core appointment)
Grtzzz
( Ps yesterday ( APC checked) not doing any stressing in the evening it happend only once...)
« Reply #24 on: November 06, 2007, 10:57:19 am »
Gerard,
Hey Peter,
I can go back to bed  Wink Just playing for 10 min Norah Jones (EAC .Wav) and the crackling apeart. ( It happends for 10 seconds and than went back to normal)
Offcourse APC is off... ( And restart after unchecking)
I will have to wait until i have a camera... Maybe i can borrow one sooner...
Will let you know....
Grtzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzznurk
« Reply #25 on: November 06, 2007, 11:48:23 am »
Camera not necessary, I believe you.
Is this repeatable ? I mean, supposed you just rebooted and all, and it took, say, 20 minutes for it to occur; could you let it do exactly the same (same tracks !) again ?
If yes, please then try it WITHOUT reboot, but restart of XX only. Then exactly the same sequence again.
And ... you still think that this is since a certain XX version, do you ? maybe re-check that ?
« Reply #26 on: November 06, 2007, 12:06:32 pm »
The camera thing i would like to do to see what give's the pike or is that not important?
I really think (but will try) that its not everytime the same again. I have the idear that whatever is giving the pike when the pike is coming at the "wrong" time/place that than things go wrong. (End of a track) But less/sometimes it comes up during playing. Mostly the crackling goes all the way to the end of a track. but rearly it is for just 5-10 seconds.
I did not try compearing models. For me this thing is from the beginning of.... And as i told you before i did not tell because i thought it was the xp driver. You know that in the beginning i send you a PM ivm the EMU DSP thing. In that time the crackling was there....
I said that there was one time i thought the crackling was less.... But as i learnt they's day's all depends on the way i/whe are using the computer. So i think that that conclusion cannot be seen with a version that was current. ( In my case)
Gr G...  Happy
EDIT: For a few day's now i thought that the crackling apears often/more in the beginning of playing. When i start the computer and starts XX today also after 10 min. But i could be wrong!!
« Reply #27 on: November 06, 2007, 01:54:40 pm »
Peter hoi,
I tried today some stress the pc some more.. and i kept on looking on processen during playing... When the crackling apears i did not see anything strange beside's the things under.... Look at what xx does.. Normally it's + 47.168 and 17.352
I said before that after a song "with" the new song is fresh/without. This is not correct.. A few time's even the next song does it. One time i moved the cursor just i bit and it was gone.... Also one time there was nothing going on i moved the cursor a litlle and than it began....
For now i give up.... And enjoy the new model.... Is great!!
Gerard...  Grin
« Reply #28 on: November 06, 2007, 06:44:55 pm »
Gerard, two questions please :
a. Do you say that you actually had the crackles, say, always ?
b. Do you perhaps say that you don't have them in 0.9pd ?
Additionally : Can you verify that you have the crackles with EAC ripped WAVs from your own origine ?
This is not about bad rips, but about the treatment for non-EAC (better : not official red book format) rips as per 0.9o. This treatment is special, and your memory listing from your earlier post may indicate that it is happening ...
Thanks.
« Reply #29 on: November 06, 2007, 07:10:44 pm »
Thanks.
Peter hoi,
A: Yes i have had the crackles as long as i remember. (beginning of XX)
B: Since yesterday i have been playing witk pd and i have them with APC checked and unchecked.
I have crackles with my own EAC rippes and with EAC ripped cd's from someone "else"... And from i know of they are very good!!!
What do you mean with "This treatment is special"
I will do a test with a model before 0.9o and specially with rips from someone else... But i am 98% sure...
Grtzzz
Pages: 1 [2] 3  All
Page created in 0.138 seconds with 19 queries.
