November 23, 2024, 01:50:59 pm *
Author Topic: No sound from Engine #2 with PCM2707 DIY USB converter  (Read 26224 times)
electrosound
« Reply #15 on: May 31, 2007, 08:11:59 pm »
Look for the Speaker icon in (Configuration) Settings (Sounds and Audio Devices). Start it.
Go to the Audio tab and click the top combobox in there. From there select your USB device.
Note though, that that will select your DAC for general computer sounds as well. Never mind those for now.
That seems to be easy
But....... the computer says no....... the box is freeze, and nothing to be set there
Well.... then I must set the USB audio device in the hardware tab to "use audio features on this device"
then restart the computer, but no.... still not able to set the box in the audio tab @#*%#
Maybe I shut some services that are accentual for that, I have tried some things but non of them helped
sorry for this all, but I can't help it
Marco
« Last Edit: May 31, 2007, 08:24:43 pm by PeterSt » Logged
Toshiba Satellite Pro, 500Mb memory, XP => USB => PCM2707 USB converter => DIY 2X TDA1541 Crown => CCS Tube output => SE 300b => DIY horns with MD3 for mid high, Beyma G350 for mid low
« Reply #16 on: May 31, 2007, 08:22:27 pm »
Yes Marco, this is related to this :
... which you apparently already have arranged for.
Please be careful here;
In the past you may have put a lot of effort to get it that far (implying KMixer to get out of the way), and if you don't like XXHighEnd you might want to do it again.
Since I hardly care about this (I don't need it because of XP bitperfect RME (Fireface) drivers or Vista where all just doesn't apply), I am a bad advisor here.
You might want to go to Bert's site to re-find what you did before (and undo it by that means), or otherwise I sure hope others can help you out.
Whatever you do, try to write it down, so you can reverse it when you think it is needed.
Btw, of course in the end you would just want to have it like you have it now (see my quote), but then including the device being the primary device.
Also note that the fact that it in the end is greyed out is not a problem, as long as you get it there (at first place hence Primary Device).
As soon as I see something to help out a bit, I'll jump in ! yes
electrosound
« Reply #17 on: June 01, 2007, 12:39:03 am »
Yes I did a lot of things, there is also the thinking of get me a new compu so a can start from scratch
About XX it's for me a hole new sound here, but I write my findings in a other topic (I need some more time to) , otherwise I get of topic here
that's a good start to find the way back, but like a say maybe a new compu is on his way
haha yes, now I wish that I had writing it down that time
Yes that is the goal yes
Well let me thank you first for all the reply s that you have given thankyou
and I'm sure that it will work some day  Wink
Marco
