April 08, 2025, 06:36:39 pm *
Author Topic: No sound from Engine #2 with PCM2707 DIY USB converter  (Read 26755 times)
electrosound
« on: May 30, 2007, 05:13:15 pm »
I get no sound from engine #2
any ideas  wacko
Marco
« Last Edit: May 31, 2007, 09:39:32 am by PeterSt » Logged
Toshiba Satellite Pro, 500Mb memory, XP => USB => PCM2707 USB converter => DIY 2X TDA1541 Crown => CCS Tube output => SE 300b => DIY horns with MD3 for mid high, Beyma G350 for mid low
« Reply #1 on: May 30, 2007, 06:09:12 pm »
Hi Marco,
Set your Primairy playback device to the one which makes sound (if everything is allright, the same as the one which makes sound with #1).
electrosound
« Reply #2 on: May 30, 2007, 06:51:51 pm »
I did.... I select my USB in the output menu
He is reading the track (the slide is moving) in #2 engine, but no sound, only in #1 engine
Marco
« Reply #3 on: May 30, 2007, 07:22:14 pm »
Doubling is off ?
XP or Vista ?
DAC settings ? (if applicable)
electrosound
« Reply #4 on: May 30, 2007, 09:04:44 pm »
I did check it, but  doubling is off
I run XP
No settings made by me, it is a PCM2707 DIY USB converter, and there is no other software that manipulate the converter, if that is what you mean?
Marco
« Reply #5 on: May 30, 2007, 09:51:39 pm »
Do you use the legacy USB driver for that ? "USB Audio Device" ?
If not, is the track smaller than 64MB ?
electrosound
« Reply #6 on: May 30, 2007, 11:12:53 pm »
Well I earlier uninstall the usb-audio.de driver
And with the next start-up XP recognize the USB device and install the legacy driver
But never mind if there is no answer at the moment, it is only for now
that I can't play large tracks
« Reply #7 on: May 31, 2007, 09:41:07 am »
Marco,
Do you mean because of the demo version ?
Or do you mean because of Engine#1 ?
electrosound
« Reply #8 on: May 31, 2007, 12:53:47 pm »
yeah, both actually  Happy
I hope that it will be solved of course in the full version or what ever, maybe it is the PCM that can't handle the
stream, in that case I have no luck
I have enough small tracks for engine #1 to test, only my reference tracks ((the one that I listen often (jazz at the pawnshop)) I can't listen
Marco
« Reply #9 on: May 31, 2007, 12:57:29 pm »
Marco, did you select your USB device as the Primary Device in Windows ?
Note that it should be at the top when you click the top combobox in XX. If it's not at the top, it's not the Primary Device, and Engine#2 requires that ...
Leo
« Reply #10 on: May 31, 2007, 01:51:59 pm »
Not my experience, I use the Total Bithead now and before the M Audio Transit as USB , neither of thsoe was the primary sound (they appear as nr 2 on the list) and both work with engine 2, also with doubling.
Leo
« Reply #11 on: May 31, 2007, 02:03:03 pm »
Leo, and the very first in the list is not "Primary Sounddevice" (or something like that, but the "Primary" is literal).
So ... that one is always the first, and the second one is always the same;
Since the first is dummy, I call the second one the first.
How about you ?  1eye
electrosound
« Reply #12 on: May 31, 2007, 04:09:06 pm »
Alright......., I have check t it, and USB is not at the top!!!
You have write it earlier (to set sound device on primary) , but I misunderstood it blush2
But I have struggled with XP, but how to set USB to primary ???.
Marco
« Reply #13 on: May 31, 2007, 04:16:43 pm »
Look for the Speaker icon in (Configuration) Settings (Sounds and Audio Devices). Start it.
Go to the Audio tab and click the top combobox in there. From there select your USB device.
Note though, that that will select your DAC for general computer sounds as well. Never mind those for now.
Leo
« Reply #14 on: May 31, 2007, 05:09:10 pm »
Of course , I should have known that the second is really the first too (or two)
Leo whistle
