November 23, 2024, 06:26:40 am *
Author Topic: Cool When Idle Is it Working?  (Read 6002 times)
« on: February 25, 2013, 10:47:02 am »
Hi Peter - since I installed 0.9z-8-2 on W7 Cool When Idle = 0 does not seem to work on my system. My Zalman cooling tower remains cold and when I check the core temperatures there is no difference compared with when I set Cool When Idle = 1.
I have rebooted to full os and back again to make sure it is engaged but it still does not seem to work. It always worked fine prior to 0.9z-8-2.
« Reply #1 on: February 25, 2013, 11:38:43 am »
Hmm ...
Paul, quick question : Did you set the other XTweaks parameters like advised (in the sense of the "better" settings) ?
Otherwise by now you may have set the Balanced Load parameter to 43 (copying my settings etc.) and that is a quite "cool" setting so you may not see a difference.
« Reply #2 on: February 25, 2013, 11:48:13 am »
And otherwise you should not have disabled XTweaks by means of renaming that NoXTweaks.tss to *.tst of course. Just saying.
« Reply #3 on: February 25, 2013, 02:02:57 pm »
Ah OK balanced load is set to 43 so that could explain it - thanks
