November 23, 2024, 11:46:23 am *
Pages: 1 2 [3]  All
Author Topic: Playback stopped because data didn`t arrived in time  (Read 43054 times)
« Reply #30 on: February 28, 2013, 09:58:00 am »
Mani, for this particular problem set your HDD spindown time to 7 minutes or more. That helped me.
Tore
« Reply #31 on: February 28, 2013, 11:51:22 am »
Set HDD spindown time to 7 minutes or more?
How do i do this?
Tore
« Reply #32 on: February 28, 2013, 01:26:14 pm »
Control Panel - Energy Settings (Power Settings) - click the link to the active scheme (usually denoted "balanced"), Advanced Settings (or something like that) and in there click "disk". In there you will see it.
« Reply #33 on: February 28, 2013, 02:39:45 pm »
By all means, do not forget to switch Off Logging !
Juan, the most logical to have helped will be the "Don't do anything with Coverart". Maybe you can confirm that ?
Sorry Peter but there is not a consistent behavior, yesterday it was working fine (not always though) clicking on "Don´t do anything with Coverart" and not working with it unmarked but today after turning On the PC the first thing I did was playing this album (C. Dion) with Show as Wallpaper active and there were no stops at all along the complete album. The only message that appeared in this case was
ChangeWp
Error setting the Wallpaper: A generic error ocurred in GDI+
These are my settings in CoverArt.
Wallpaper Max Height: 400
Thumbnail Cache Size: 500
Coverart-Resize Size: 3000
So, the conclusion so far about the "Playback stopped..." message is that the behavior is erratic and that when it stops just trying two or three times it works again not necessarily changing any setting.
« Reply #34 on: February 28, 2013, 03:38:28 pm »
Juan, the Wallpaper error is harmless. I know how that happens and it should not be and must be solved sometime. I have it too half of the times now when starting Playback (and SFS=1).
Diede
« Reply #35 on: February 28, 2013, 10:14:45 pm »
I get the same error message "Playback stopped because data didn`t arrive in time" in 1 out of 3 (more or less) cases.
Even worse, sometimes XXHE shuts down completely in the middle of a song.
Disableling the page file didn't change a thing.
Like Juan, without changing the settings it can sometimes work or not.
My settings are the same in W7 as under W8 (see signature).
Diede
« Reply #36 on: February 28, 2013, 10:57:00 pm »
I have a shut down so now and than. The pc just freezes and a hard reboot is needed.
With the previous version i had a blue screen when it happens.
that does not happen with this version.
Will play with some settings when i have time.
No errors about data ect..
nik.d
« Reply #37 on: February 28, 2013, 11:30:17 pm »
@Diede
You are running music from USB disks. Please try and change computer power plan into this:
Control Panel / Power Options
Down arrow on right side: Show additional plans
Choose High performance / Change plan settings / Change advanced power settings
Hard disk: Turn off hard disk after: '20 Minutes'
(default, it should be OK for most but classical music with longer pieces)
One more power plan change:
 USB Settings/USB Selective suspend setting: 'Disabled'
HTH
George
« Reply #38 on: March 01, 2013, 01:13:51 am »
For the record:
This message appears now and then when playing music with 8-2. Sometimes in a track that I just started, sometimes along an abum, but sometimes i can listen to a complete range of 60+ minute albums without a stop. When i switch tracks i've encountered 8-2 won't start playing the new track at all.
This is a 8-2 thing on my system. No such behaviour in 8e. Settings are really different though, now pa is engaged (-1).
Removing engine3 by pressing the "off" button in the q settings area helps for all above stops or not-starts.
Regards, Coen
« Reply #39 on: March 01, 2013, 08:14:22 am »
Ok, what about this :
It seems a kind of logical to me that everybody started using (Xtweaks) Balanced Load at 43. But mind you, this turns -for example- a 3GHz processor into a just over 1GHz processor. Ah, you didn't know that. Well, it is so.
So what about setting it back to how you had it before ?
And do not fall into the pitfall of now seeing a message where before the sound just stopped unnoticed, because it really is the same !
« Reply #40 on: March 01, 2013, 10:41:11 am »
As I'm only using a single HDD for OS, XX and music nowadays, I have the HDD set to 'never' spindown.
« Reply #41 on: March 01, 2013, 10:52:45 am »
So what about setting [the Balanced Load] back to how you had it before ?
Just tried taking Balanced Load from 43 back up to 85, as I had it before. I only played a few tracks and had no stops - but then this is usually the case with 43 too. However, I prefer the sound of 43. It's 'calmer' and less 'in your face'.
I'm still not sure about 'Cool When Idle' though. Even at BL=43 this seems to have a profound affect on the sound. When set to 0, the sound becomes silky smooth... but to the detriment of fine detail IMO. Set to 1, the sound opens up and instruments start vibrating and 'singing' as though they're alive. The only downside seems to be a bit of sibilance. I strongly suspect this has something to do with noise, either in the SMPS or mobo. I don't know which way this works though; is the noise higher with CWI=0 or 1? But the difference seems more pronounced with higher BLs (say 85).
In any event, with my current setup, I prefer CWI=1. Maybe if I had a linear PS my preference would be different...
Edit: Haha, when I'm sitting in my home study/office listening to the music playing (pretty loudly) in the main room, I think CWI=0 sounds more real - beautifully balanced and nothing annoying whatsoever.
PS. Peter, many moons ago you mentioned something that was even crazier than your normal 'inventions' - a linear PS for a PC that was the size of a matchbox, or something like this. Did anything ever come of this? Your sig suggests you might already be using something like this. Are there any beans to spill at this point in time???
« Reply #42 on: March 01, 2013, 01:48:37 pm »
Mani, no, I am sorry. The "matchbox" was put on hold somewhere a year back. Had something to do with CE regulations, and without that certificate it would catch fire.
Well, something like that. It is not completely dead though.
« Reply #43 on: March 03, 2013, 02:47:37 pm »
Like Mani, I have my HD spindown set to "never". In a four hour listening session I had this error five times.
« Reply #44 on: March 07, 2013, 04:09:27 am »
Well for the last three days this error message hasn't occurred. The difference: my wife swiped my flat screen for a work project and I dug an old CRT out of the closet. Viola!
Pages: 1 2 [3]  All
