November 23, 2024, 01:47:27 am *
Author Topic: Fuse  (Read 27533 times)
« on: February 21, 2013, 10:46:00 am »
Hi Guys,
Wanted to share my experience with high quality fuse as compared to std fuse.
A few days back I replaced the fuse in the NOS 1, preamp & amps with HIFI Tuning Supreme Fuse. The results are outstanding. The harshness in the mids & highs is significantly lower...the sound tends to get more musical & has a lovely softness to it. Separation within different instruments is greater. Overall clarity is audibly improved without getting clinical.
At $ 60/80 a piece, its steeply priced, but in my opinion a tweak well worth it.
« Reply #1 on: February 21, 2013, 11:19:38 am »
Hey Arvind,
Funny. I think it really is the only part of the NOS1 I did not pay attention to. Possibly because I don't believe much in these kind of "tweaks". But I sure believe *you*.
Do you have a link to that product ? I now like to try it myself. Others might too (note that two of those fuses are needed !).
Thank you Arvind.
« Reply #2 on: February 21, 2013, 12:10:28 pm »
I bought these off their stockist in US, The Cable Company, link http://www.thecableco.com/Product/Supreme-Small--20mm--75--Fast-Blow--F--Type
Being a German manufacturer, HIFI Tuning should have stockists all over Europe.
« Reply #3 on: February 21, 2013, 12:17:27 pm »
I would certainly be willing to get 2 of them also... I sure hope that someday, someone will come up with an explanation about the improvment felt with these devices ?
Alain Happy
« Reply #4 on: February 21, 2013, 12:38:03 pm »
Hi Alain,
I gave a feedback to Ken Stevens of CAT for his preamp & amps. His reply was very interesting. He found the same improvement when he bypassed the fuse. Of course it can't be done at production level. He too believes that this could be the near best solution to the fuse problem.
« Reply #5 on: February 21, 2013, 12:41:52 pm »
Hi Arvind,
Thanks for the note Happy I will look into it.
Like someone uses to say: "Everything matters" Happy
« Reply #6 on: February 21, 2013, 02:19:14 pm »
Hey guys what's the proper fuse value for the NOS1? I'm traveling so I can't "pop the lid" and look at the fuse. Thanks.
« Reply #7 on: February 21, 2013, 02:31:15 pm »
Brian, 1000mA for your 115V.
500mA for 230V.
5x20mm.
"Half slow" type.
« Reply #8 on: February 21, 2013, 02:40:56 pm »
HiFi tuning, like most other fuse manufacturers don't make half slow blow type. It's either fast or slow blow. I have installed the slow blow type as recommend by HiFi tuning.
« Reply #9 on: February 21, 2013, 03:11:27 pm »
Thanks Peter.
Eric
« Reply #10 on: February 21, 2013, 03:38:47 pm »
I am using these fuses since many years.
From my experience I can confirm that the type/quality of fuse makes a significant difference. It makes sense, because all power needs to pass through that thin, small wire. The biggest difference was in my phono preamp, but also the NOS1 DAC delivers a sound that is more solid ("grounded") and has a bit more microscopic detail. For example see http://www.kempelektroniks.com.
By the way, my NOS1 DAC is powered through a Power Station that delivers Regenerated, Balance power (same website).
Eric
« Reply #11 on: February 21, 2013, 04:47:10 pm »
Interesting a small length of silver wire impregnated with 1% gold. Does that make a difference? It would not surprise me if it did. do the makers / suppliers understand why it makes a difference? - I doubt it.
So I reckon it could make a difference in your systems but I have a hunch it would not make much (if any) difference in my system.
So Peter if you do buy 2 fuses and they do make a difference in your system maybe afterwards ship em over to me and I will try them in my system.  I bet you a(nother) bottle of whisky they would not have much (if any) noticeable difference in my system (maybe Nick could lend his "honest ears" for a second opinion)
If my hunch is right I will explain what I think they do (but not how they achieve it).
Ha ha
« Reply #12 on: February 21, 2013, 05:13:27 pm »
Hi Paul,
you'll be surprised, and .............. buy one! Wink
« Reply #13 on: February 21, 2013, 05:58:54 pm »
Hey Joachim, and where to put that one ? Phase or Neutral ?
hahaha
« Reply #14 on: February 21, 2013, 06:24:45 pm »
hahaha
BUY ONE BOTTLE !!!!
