November 23, 2024, 09:37:43 pm *
Author Topic: 09-z8-2 and Stop All Services  (Read 19063 times)
« Reply #15 on: February 22, 2013, 08:40:06 pm »
Mowa,
I had some trouble with this settings at start too.
but this is the way i have it now.
Maybe it is more clear.
mowa
u are what u is
« Reply #16 on: February 22, 2013, 08:55:53 pm »
Hi Peter and Gerard,
What do you mean "and playback isn't running" ?
You must click away that message of course ...
Well...playback isn't running at all, when i click away the message music isn't playing and i see a blue screen (Not the BSOD)
Only thing i can do is hitting ALT+S / ALT+X.
Thnx, but i've no trouble with the settings though.
(Power) Monster HDP 750G Powercenter / Ke-Lo Power cable
(Source) Windows7 Ultimate X64 on Samsung 830 series SSD 128GB, Playback drive: Samsung HD753LJ, Intel Core i5, 8G RAM (Kingston HyperX KHX1600C9D3T1K2/8GX), ASRock Z77 Pro4-M
(XXHighEnd-09-z6-1) KS: Global / Engine#4 *Adaptive Mode* / Buffer 1024 / Q1/2/3/4/5 = *1*/0/0/0/0 / Scheme-4 / Playerprio = Normal / ThreadPrio = RealTime / Dac: 24bits 96.0K (24 bit only dev.) / Services off , Running Time OSD on / Unattended
(HiFi) Standard USB cable to HRT Music Streamer II+ / QED Qunex 4S / Stax SRS 4040-II + SRM-006t II
« Reply #17 on: February 22, 2013, 09:28:01 pm »
So each time you attempt playback the message appears again ?
What if you reboot (just via Start Button) and try again ?
scratching
mowa
u are what u is
« Reply #18 on: February 22, 2013, 10:58:26 pm »
After some hours of trial & error finally solved..!! wacko
The error was apparently caused by the GPU driver  WTF !  oops (AMD HD7950,the system also acts as a game pc = dual boot on 2 SSD discs)
After deleting GPU drivers and Catalyst control center it now works like a charm.
Man, 09-z8-2 sounds really sounds more analog..!! I now hear the wood from the violin (Bach: sonatas and partitas, Isabelle Faust) and the mechanism from the fortepiano (Kristian Bezuidenhout on his last Mozart cd). I can estimate the size of a Steinway and there's more depth in the soundstage.
Very, very good job..!!
i'll change my sig and after that i'll enjoy a "cd" or 2 (maybe 3)
