November 23, 2024, 10:47:26 pm *
Author Topic: RDC Problems  (Read 26574 times)
« Reply #15 on: February 01, 2013, 02:04:20 pm »
OK, I've given up on this for now. Will get back to it another day. Have reverted to using RDC via LAN - worked first time...
« Reply #16 on: February 02, 2013, 10:12:37 pm »
Hi Peter - I have just used another disc to make a completely clean install of W8 (from an OEM disc) as opposed to upgrade to W8 from a clean W7 install. All I have done is to install XX and get it working - no problems and XX works fine (and oh boy do I still like the SQ with W8). So then I installed the remote control Bluetooth - made a pairing between my laptop and PC (fine no problems there) and attempted to RDC connect. Again it did not work but after that it is impossible to run XX - I press the "Start" button and nothing happens. And as before there is no way out but to restore to a time before the Bluetooth drivers were installed to get it working again.
And yes of course I did try rebooting before I restored and no it did not sort out the problem.
RDC works fine if I connect from the laptop to the PC via the hardwired network connection but that affects SQ which is even more noticeable under W8 so I prefer to have the network switched off.
« Reply #17 on: February 03, 2013, 09:41:53 am »
In addition to the above at the last reboot when the login screen comes up I cannot use a keyboard and mouse however connected either hard wired or by USB. I can use the keyboard to get into BIOS but not after windows comes up.
So it does appear that something bad happens in the OS when I try to connect by RDC over bluetooth.
« Reply #18 on: February 03, 2013, 10:18:14 am »
Paul, I am very sorry, but I don't know where to go. I don't know whether it was in this topic that I said I needed 500 or so reboots to get a similar thing going, but today I am over a 100 more. So what do you expect me to do for help. Windows 8 is different and this is an OS issue somewhere. Until we understand, then all is fine again. Yea, well ...
What I would do is boot into Normal OS in all circumstances to get this going. This is of major importance because of services needed. And what I know by now is that W8 won't start services itself where it did with W7. It is too hard to explain, but it leads me to you telling to test it in Normal OS Mode. If that already doesn't work ...
Of course things get totally odd when Play in XX already won't work anymore because of this. I have no clue.
Best would be to learn not to use it because otherwise you will loose all of yor time on this. I do too. Can't do a thing for XX itself for months, only because of such a thing. Back to that in an hour or so ...
« Reply #19 on: February 04, 2013, 08:10:20 pm »
Hi Peter - it is not the end of the world if I cannot use remote but it would be nice to have again sometime  unhappy. But look at the message that W8 generated.
I did actually achieve a bluetooth pairing without problems so I thought it would be the RDC that was the problem (and in fact the system problems only occurred after attempting to use RDC. Maybe it is some interaction between the two.
By the way I always boot to full O/S to load software and make any significant changes.
Not sure why I got this error message as the Broadcom download shown on their website is the same and that is W8 compatible.
Cheers P
« Reply #20 on: February 05, 2013, 09:38:46 am »
And, what did you answer Paul ?
« Reply #21 on: February 05, 2013, 09:43:01 am »
By now I have heard similar things from others. Well, similar ... the OS messed up. But why not here at my place ??
Alain, didn't you say you just got it running easily ?
Sorry I forgot, but what W8 version do you use ? Mine is Enterprise.
« Reply #22 on: February 05, 2013, 11:18:13 am »
Hey Peter - I can't post here how I responded as this is a decent blog and you would probably have to delete it.
Oh and my W8 OS is Pro
« Reply #23 on: February 05, 2013, 11:21:40 am »
Well it worked after you sent me a second Broadcom version. No problem then. But as you know I can't use bluetooth anymore (one of my dongles died)...
My version is 8 pro x74 (French)
« Reply #24 on: February 05, 2013, 11:35:00 am »
Alain, stupid question perhaps. But I didn't send you TWO versions for W8 did I ? If so, just fire back that email to me with the version which worked for you. I may be sending a wrong version to everybody ...
... With the notice that I must be having 20 versions myself for all the trialling ...
« Reply #25 on: February 05, 2013, 12:39:54 pm »
Paul (and others) - I've had a response from Alain and must work out a few things. Will do that later today, hopefully.
« Reply #26 on: February 05, 2013, 07:17:13 pm »
You all received the same Driver as Alain did ...
