November 24, 2024, 12:54:48 am *
Author Topic: LAN Activation fails  (Read 7698 times)
andy74
« on: October 29, 2007, 01:14:04 pm »
I have just tried to activate XX on another PC LAN connected to my PC where I have XX activated (versions d,j,k,n,o,p all activated in their own folders).
I copied the folder from my PC to another. then run XX from that PC and entered the path to my PC as described in activation how to.
Then I hit activate button, message "Path is OK!", then "Activation will be taken from that PC" or similar showing up, and then Activation failed shows up, it quits and I stay in Demo mode.
What am I doing wrong?
Andrey
« Reply #1 on: October 29, 2007, 02:39:12 pm »
Hmm ...
Since you copied the whole folder from the originally activated PC ... could you delete the .DAT file on the "new" PC and try again ?
If this helps, it is just something I did not think of ...
andy74
« Reply #2 on: October 29, 2007, 02:52:52 pm »
I tried it. did not help.
I even tried to unzip clean copy to another PC ant try to activate via LAN. did not work either. unhappy
What else can I try?
« Reply #3 on: October 29, 2007, 03:06:10 pm »
Read your PM. Happy
Sorry for the inconvenience.
