November 23, 2024, 12:27:21 pm *
Pages: 1 2 [3]  All
Author Topic: Musings on digitizing vinyl  (Read 48164 times)
« Reply #30 on: January 28, 2013, 02:44:51 pm »
It's not really how I'm hearing things. I have a slight preference for the 16/44.1 vinyl recording over the CD rip. Oh, I forgot to mention: you need to disengage HDCD in XX before listeing back to the 16/44.1 recording - hdcd.exe isn't very clever and thinks HDCD peak extension has been used, when it hasn't.
In any event, the 24/176.4 recording is much better than the CD rip... at my place at least. Maybe you need to get some better amps... haha.
« Reply #31 on: January 29, 2013, 08:50:29 am »
Mani, no. I know that "analysing" this sh*t is difficult, but your LP goes to 15KHz just the same. The remainder is sheer noise. Sorry about that, but this is how I see it.
The main difference is the "amount of information" you hear.
The amount of steps of a sinus curve at files with 16/44,1 are smaller and the height bigger than .............. .
You hear more refined vibrations of the guitar string at 24/176,4 than ................ .
So, the amount of  steps is higher and the height smaller at 24/176,4 at the same sinus curve.
« Reply #32 on: January 29, 2013, 10:03:13 am »
Hoachim,
The height is smaller ?
Can you elaborate somewhat ?
« Reply #33 on: January 29, 2013, 10:43:16 am »
Please see the link
http://www2.leuphana.de/medienkulturwiki/medienkulturwiki2/images/4/45/Digitalisierung.png
I'm not so bright to insert the image into this post. Copy and paste does'nt work, even if I press "Insert Image" before.
« Reply #34 on: January 29, 2013, 10:50:38 am »
Here you go. "Save target as".
« Reply #35 on: January 29, 2013, 10:51:30 am »
But now you must be so bright to elaborate. Happy Happy
« Reply #36 on: January 29, 2013, 11:13:14 am »
As a sample,
over one second
the amount of steps ( 0's and 1's) are increasing with the sample rate, you get more informations (overtones, please see http://www.music.vt.edu/musicdictionary/texto/overtone.html) about the same impulse. yes
« Reply #37 on: January 29, 2013, 11:19:00 am »
Ok, you had your chance. Happy
Incorrect. The relation between 16/44.1 and 24/176.4 is :
16bits:24bits = 1:256 (= your height)
44.1:176.4 = 1:4
So, height is 256 times more, while sample rate is only 4 times more.
If this is not what your subject is, then ... please elaborate.
haha
« Reply #38 on: January 29, 2013, 11:33:52 am »
What a bad example pic. There is even a phaseshift between analog and digital domain, never seen that before.
This is a totally useless pic to make any other point than that the drawer didn't understand sampling either (probably a marketeer).
Just a warning: Digital theory is highly abstract and mathematical. Not much if anything in there that is inutitive or will explain "better" sound. Implementation of it in electronics is more of an experimental art than science, though Peter is on to some principles by now! I think the field of psychoacoustics will provide for better insghts in our sound perception of various formats and recording/playback means. Much generalisations in there and little attention for the "high-end audio" however.
regards, Coen
« Reply #39 on: January 29, 2013, 11:44:43 am »
44.1:176.4 = 1:4
haha
He, he
now I'm trapped!!! Happy
In general my intention is to say, coming back to my first quote, that it is not sheer noise, there are more overtones on the LP.
P.S. Is there a better program than Audio Gate on the market?
« Reply #40 on: January 29, 2013, 12:15:39 pm »
If that were so, it would show as frequencies. It takes a bit to learn "reading" such graphs, but here there is nothing. Just fairly random noise (beyond 15Khz I mean).
Obviously I challenged for the question, but although I don't know, there will be undoubtedly. Well, "others" and I don't know about "better". But you can look at it as downsampling. really dozens of programs exist for it, and they all behave differently (notice that DSD-PCM actually is a form of downsampling or "decimating"). The one is worse than the other and possibly none is good. Too many variables involved.
And then there's the subjectiveness of theories. So, take Arc Prediction for "filtering" (generally called "upsampling"). Here too dozens and dozens exist. Now go find one better behaving than Arc Prediction. You might find it theoretically, but personally I don't think you will. So here it is the technique used which is subjective to my ideas. And it is practice (or objective) once it is clear that it works for the better and best.
Do you see ? this is how I can say that e.g. Audio Gate isn't worth much. Too few parameters and what can be applied gives a result at least I don't like.
There's much more to say, but this is all in the DSD realm and already that us subject to "is that better ?" in the first place.
It's a large subject Joachim. One thing : it determines SQ, just like Arc Prediction does that for your NOS1 ...
« Reply #41 on: January 31, 2013, 10:51:21 am »
The digitized LP files (EMT 950, EMT XDS, KORG MR 2000s, Audiogate software;  192KHz/24bits (superior to 96/24), )
are totally different in SQ to CD files  via XXH.
Instruments on CD files are well seperated, less soundstage, cymbals are more harsh , but I like it.
LP files smoother SQ  and nice soundstage
Christoffe
Disengage HDCD during replay of digitized LP files (192KHz/24bits) is mandatory. (see also Mani's note before)
« Reply #42 on: January 31, 2013, 10:57:04 am »
I don't think there is an HDCD flag in 24/192(176.4) ...
« Reply #43 on: January 31, 2013, 11:16:14 am »
Actually, there is! If you have an Alpha, an Esoteric D70 or a PMII, the HDCD light will come on with 24/192(176.4) material...
... provided these files have been recorded on a PMII, as no other ADC will encode HDCD at any rates.
BUT the HDCD decoding in XX should not detect the HDCD flag at these rates. So having it set to on/off in XX should make no difference.
Pages: 1 2 [3]  All
