April 05, 2025, 05:25:15 am *
Author Topic: XXHE 09-z8-1: W8 in unattended mode does not close opened windows  (Read 8126 times)
« on: January 21, 2013, 12:40:19 pm »
I noticed that when I open a window prior to going into unattended, it stays while the music play.
« Reply #1 on: January 21, 2013, 12:44:47 pm »
Alain,
That depends on the "window". So, what do you mean - which program etc. ?
« Reply #2 on: January 21, 2013, 01:07:41 pm »
Alain,
I could be a "My Computer" window for instance... I did not really go further than this...
« Reply #3 on: January 21, 2013, 01:43:15 pm »
Well, I know that several "standard" programs (like MyComputer) are bound to Explorer in Windows 8. And, Explorer is a kinf of special. So for example, if you put the Control Panel to the Taskbar, you can see that under this taskbar-icon several Windows programs open (you would say "hey, where is my Control Panal now ??".
Iin other words : I reckon that you shouldn't leave Windows programs open in general (because they may not close). But if it were for other normal programs ... they shoul close.
« Reply #4 on: January 22, 2013, 03:54:30 pm »
I will try this evening with something else than My Computer Happy
Page created in 0.015 seconds with 19 queries.
